mk1kid 0 Posted September 7, 2011 Report Share Posted September 7, 2011 hi all got a 95 vr6 obd1 had it for 3 weeks now but getting a real bad vibration when pulling away the whole car shakes really bad i was thinking either clutch problem or engine mount or has the previous owner fitted solid mounts i dont have a clue what to do or check i noticed when standing looking at the engine the passenger side looks lower i took out the battery tray to see if anything visible but nothing any help please its bugging the hell out of me Link to post Share on other sites
p0u1 14 Posted September 7, 2011 Report Share Posted September 7, 2011 mines done that for the last 6 month because im too poor to change my plugs affter i bought my ht leads, but yea i would say its missing Link to post Share on other sites
Vw_owner 1 Posted September 7, 2011 Report Share Posted September 7, 2011 could be a number of things,me and my m8 re fitted an old set of wheels with uneven worn tyres to a car we got for nothing and the wobble/vibration we got off that was unbeliveable!! , seeing as you have only just got the car i would check the wishbone bush's,wheel bearings,engine mounts,tyres,wheel bolts if you dont know how to check any of those just go on youtube and search "how to check .............." your learn a lot if your willing also my vr6 and many others sits lower towards the passenger side. hope this helps.. Link to post Share on other sites
mk1kid 0 Posted September 7, 2011 Author Report Share Posted September 7, 2011 il keep on checking things ive rocked the engine nothing moves so thats a good sign lol replaced plugs so its not them Link to post Share on other sites
russj249 2 Posted September 7, 2011 Report Share Posted September 7, 2011 If i think it's what you mean it sounds to me like the clutch isn't aligned properly or slipping then gripping then slipping if you know what i mean, possibly by fluid leaking onto clutch plates.there's a rubber inspection hatch on top of box. remove that and see if there's and spray.hard to say without seeing it, but that's my input anyway Link to post Share on other sites
mk1kid 0 Posted September 7, 2011 Author Report Share Posted September 7, 2011 my first thought was clutch but it doesnt slip Link to post Share on other sites
VeeRsix 0 Posted September 7, 2011 Report Share Posted September 7, 2011 Lo M8Vibration=Somethings out of balance or broken and not performing the damping its intended to.A few things to check out ie driveshafts/wheel bearings/clutch/mountings/suspension especially broken coil springs.Stephen Link to post Share on other sites
rodney 17 Posted September 7, 2011 Report Share Posted September 7, 2011 We need a bit more a description please mate...Do you mean every time under acceleration or only when you change gear or only when you pull away?If only when you pull away then check clutch fluid levels first off then start to look a little deeper at the clutch... we need to know if it is felt through the pedals or gear lever or even steering wheel mainly etc..If any time under acceleration clean your plugs and check your Dizzy and HT leads... (when was the last major serive undertaken???)As for engine mounts.. if you accelerate fairly hard lift off and back on the gas again you should be able to feel that quite clearly and that'll point towarsd the engine mounts..Answer those for us and then we can talk in more depth with you... Link to post Share on other sites
mk1kid 0 Posted September 7, 2011 Author Report Share Posted September 7, 2011 hi rcf well its deffo when pulling away can feel it a little on tickover but as i pull away the whole dash vibrates cant feel via pedals or steering if i reverse of my drive and pull away it vibrates like mad but if i rev it up as i pull away its less vibration thats why i thought a clutch problem the coilovers are fairly new hope that helps abit better Link to post Share on other sites
NIJVR6 0 Posted September 7, 2011 Report Share Posted September 7, 2011 does it do the same when runnin hot? or less severe Link to post Share on other sites
mk1kid 0 Posted September 7, 2011 Author Report Share Posted September 7, 2011 yes all the time im tending now to put more revs on all the time to try eliminate it as it feels horrible vibration Link to post Share on other sites
Ian_rogers 0 Posted September 7, 2011 Report Share Posted September 7, 2011 Is there any strange noises? Link to post Share on other sites
mk1kid 0 Posted September 7, 2011 Author Report Share Posted September 7, 2011 nothing really idles a bit rough but thats it Link to post Share on other sites
p0u1 14 Posted September 7, 2011 Report Share Posted September 7, 2011 the blue coolent sensor? if thats shot it might cause your engine to run really rich, is it only when your engaging the clutch or does it still do it when your rolling and put your foot down in gear? i know my car does all the things your saying, like i cant drive in a 30 zone in 5th gear i need to be in 4th,i need to shift down to 3rd if i slow down a tiny bit, i have good i dear that mines doing it because off the bad spark plugs, pay days soon hey! Link to post Share on other sites
mk1kid 0 Posted September 8, 2011 Author Report Share Posted September 8, 2011 could it be the diff in gearbox how can i tell also when idiling and move steering a little from left to right it vibrates also Link to post Share on other sites
Vw_owner 1 Posted September 9, 2011 Report Share Posted September 9, 2011 have someone look in the engine bay whilest your sat in there reving the engine turning left/right etc Link to post Share on other sites
