Which BOV for my application??
Hi,
I'm currently bulding up the bits I need for my turbo conversion. Have most of the bits now but I'm stuck as to,
A. Do I need to run a BOV (which I assume I do)?
B. Does it need to be a re-circulating BOV?
C. What make/size is best for my setup?
I'm going to be running the stage 1 C2 software with 30#injectors and standard MAF.
Cheers,
Brad.
you should use a re circ because your using a maf sensor. venting to atmosphere will make it run super rich off throttle. maybe get flames but do more damage than its worth.
as for size, bigger is better. the quicker you can disperse the boost air, the less chance of trying to spin turbo backwards. i have a forge supersize that's 38mm instead of the conventional 25mm.
