23345matt 0 Posted September 14, 2011 Report Share Posted September 14, 2011 As above I keep getting a squeal when driving. It a mk3 vr auto. It does not do it when under heavy load just when I am cruising along at constant speed. But when I lift off the accelerator pedal it goes. Any ideas guys would really hel me out. Link to post Share on other sites
23345matt 0 Posted September 14, 2011 Author Report Share Posted September 14, 2011 Just discovered that my in ddrive shaft boot on the drivers side is split. Could this be the cause of my squeel? Link to post Share on other sites
VR6Pete 1,455 Posted September 14, 2011 Report Share Posted September 14, 2011 maybe, have you checked your serpentine belt too? Link to post Share on other sites
23345matt 0 Posted September 14, 2011 Author Report Share Posted September 14, 2011 checked that seems fine, it is doing it now accelorating and decelorating, Nothing if it is in neutral and blip the revs just when in gear and moving Link to post Share on other sites
Vw_owner 1 Posted September 15, 2011 Report Share Posted September 15, 2011 check the belt tensioner bearing, you will need an m8 bolt, skrew that into the tensioner to release the tension off the belt and then spin the roller to see if it has no grease... Link to post Share on other sites
23345matt 0 Posted September 15, 2011 Author Report Share Posted September 15, 2011 will do cheers, when driving seemto come from the gearbox side but could be resonating threw cab, im stumped Link to post Share on other sites
