Cabrio project - VR6 3.5 street built
  • Replies 228
ahhhhh forgot to mention i found the reason behin the lumpy idle.... and a member on here was right... air leak.....
no idea what its for, but seein as i have done away with the carbon cannister, i presume it might of been for that, but blanked it off and hey presto..... runs as soomth as silk... :)
ahhhhh yes, i have removed all that, so thats where it went, so i have just blanked it off. lurvly.......
i got some decent rims to go on my cabby now......
sneak peak.....
take em off my T4, 16x8 i need to get some 25mm rear adapters n some 15mm fronts will stance it out loverly.....
i'm not sure tho wether to have them sprayed crinkle black and keep the lips mirror polished - or keep em polished....
thoughts?
finally dropped off the mk3 front wings off to me spray guy, side repeates are being smoothed out the vento bonnet is being sprayed along with a color coded grill and my smoothed front bumper, polo 6n2 rear door handles and polo stubby mirrors is all being sprayed...
hopefully end of the week they will all be back with me sprayed up....
aaaaannnnnssssssuuuummmmmmmmmmmmmmmmmmmmmm
thanks dude :)
just trying to think of the best way to "tidy" the wiring, i suppose some heavy duty electrical tape wopuld be a good option then buy some more plastic wire covers....
as mentioned samco i think is a deffinite go. and polished rocker and inlet also.
i got a sweet little idea for the boot of the car.... so gonna try n put that plan into action and see how that plays!
well.... jobs a goodun....
i set about today wanting something differnt to every other car at a show etc.... so i went to work on the boot.....
Firstly, i built a frame out of 4X2 & 2X1...
got the fame in and mounted the first part of 12mm MDF
slotted the 2nd part in....
during.....
AANNDD the finished boot....
stoked with it, i'm now on the look out for a retro/vintage picnic set to display in the back when i go to a show....
Happy...
Also ordered some satin sand paint to paint the engine bay and boot area..... and fitted a fan overide switch as for some reason it wasnt working..... hmmmmm
well, done a little more today.... run the headlight loom down chasis leg, and painted the drivers side in my satin sand paint....
will put another coat on tomorrow, and look into hiding the engine loom plug etc happy until i broke the AUX water pump.... what a douche bag!
Well see in as I totally fubard up yesterday I thought it needed a fresh look in the bay,
Now my plan is to go semi smooth bay, loose the battery loose the header tank and possibly loose the washer bottle. Not sure yet if I wanna go that far as the intention was just to loose the wires as a flipping hate see in wires in a bay - pet hates n all that!!
So, I ordered some satin sand military paint - hammerite pretty much. And put a coat on to see how it looks.
Now this is a first coat without and wet flatting, I plan on puttin on about 3 coats with a 1500 wet flat between them to try and loose the brush lines.
Anyway. Here.
Will look good against the brown.....
Think see in as I got plenty of time on my hands will probes drop the engine and subbframe out again to clean it up and paint it.
found this in my cupboard the other day....
a nice 1.2L washer jet bottle with a 1 way pump, must of been for the mk2 i was going to smooth out the bay, it looks small enough to tuck under the scuttle pannel....
a job to do after i have sorted out why the car wont fire after i have extended the wires!!
bugger!!!!!
well done some more tonight in half an hour,
got the engine ready to come out, all thats left to be done is split the drive shafts away from the gearbox and lift the engine n box out and it's go go go :)
my best mate come over tonight, said that he will plate up my chasis legs for me.... best thing having a best mate as a farmer!!
then it will be cleaning up the engine time and other bits around it and the car can go up the bodyshop to all be sprayed!!
so, cracked on with the rest of it today, got the engine and box out. Put it on a pallet and wrapped some blue tirpolin over it to try and keep it dry etc.
Started to remove bits and pieces, dumped the ABS unit and the loom....
Dumped the old rusty/rotten PAS pipes and then relocated the PAS bottle to drivers side wing, ordered custom PAS braided lines to run along the chasis legs so there hidden,
split my old loom again so i can pull all the wires inside the car and start to get to work on fixing the fubard loom!!
so i got a few snaps to keep y'all happy!!
How we started at 10am :)
A few last bits to do before this is out
Split drive shafts...
engine ready, engine crane in place :) .....
Engine out:
Dumped the ABS Unit...
and the relocated PAS bottle....
and with the front pannel in.... loads of room for the headlight:
More tomorrow if the weather gets better..... HOPEFULLY!!!!
