vr6guy 29 Posted October 10, 2011 Report Share Posted October 10, 2011 Hi guysi have mk3 vr6 turbo, have finished my turbo engine install now but engine is now overfuellinghad it running with foot flat to the floor for 15 mins ish and car would only rev to 3000rpm and used nearly £20 worth of juice in that time!!! thats how bad it is.its soaking the plugs and making it misfire and have changed oil twice now due to fuel mixing with oil.have checked coolant sensor on diagnostic - okmaf - oktried cleaning plugs and putting blowtorch down plug holes to burn off fuelunplugged fuel pump fuses and taken plugs out with coil pack unplugged and turned over to clear the pistons but have had no luck....i think its just flooded from where it has been sitting as it has got worse and worse.any other things i could do to check?thanks guys Link to post Share on other sites
legvw 0 Posted October 10, 2011 Report Share Posted October 10, 2011 Are you using the correct fuel pressure regulator? Link to post Share on other sites
craggsy 91 Posted October 10, 2011 Report Share Posted October 10, 2011 More info needed really.What injectors?What remap?etc etc Link to post Share on other sites
bungy 2 Posted October 10, 2011 Report Share Posted October 10, 2011 You need to be really careful that you don't wash the bores if it is over fueling that much. Have you put larger injectors in by any chance and if so what size are they? Link to post Share on other sites
J5KE F 0 Posted October 10, 2011 Report Share Posted October 10, 2011 Answers to questions = results..We like vrt's Link to post Share on other sites
vr6guy 29 Posted October 11, 2011 Author Report Share Posted October 11, 2011 Vr turbos are the nuts!!! it has a chipped ecu but dont no what oneHas 440 injectorsNot sure what regulator it is, it all came with the engine when I bought it...maybe the regulator isnt plummed in properly? At the end of the fuel rail on the right side it is standard looking... Is that right? I shall get some pics asap as well. Link to post Share on other sites
VR6Pete 1,455 Posted October 11, 2011 Report Share Posted October 11, 2011 I dont think a chip would suffice, you really need to get it remapped on a rolling road before any long term damage is caused... Link to post Share on other sites
bungy 2 Posted October 11, 2011 Report Share Posted October 11, 2011 If your ECU isn't set for the size of injectors you will be over fueling by a factor of 2.5 times what it should be. Link to post Share on other sites
vr6guy 29 Posted October 11, 2011 Author Report Share Posted October 11, 2011 hi guys ECU is chipped for the 440 injectorsbasically i bought the running gear all in one and have fitted to my vr6, so i havent changed anything from when it was in the other vr it came out off, which it ran fine in.....i have reduced the exhaust from 3" to 2.5" as well, dont no if that makes a difference. here is engine beforehttp://www.youtube.com/watch?v=_IZBEA5ZepA&feature=relatedhere is engine nowhttp://www.youtube.com/watch?v=L93EQSqkKRo Link to post Share on other sites
UnitedMotorsport 55 Posted October 11, 2011 Report Share Posted October 11, 2011 So you appear to have no boost reference line connected to the waste gate?The EVAP connection on the manifold open to atmosphere, and a dump to atmos dump valve? Link to post Share on other sites
legvw 0 Posted October 11, 2011 Report Share Posted October 11, 2011 So you appear to have no boost reference line connected to the waste gate?The EVAP connection on the manifold open to atmosphere' date=' and a dump to atmos dump valve?[/quote']I seam to remember a thread on those issues a while back, with the same video.Have you plumbed the fpr in correctly? Link to post Share on other sites
vr6guy 29 Posted October 12, 2011 Author Report Share Posted October 12, 2011 So you appear to have no boost reference line connected to the waste gate?The EVAP connection on the manifold open to atmosphere' date=' and a dump to atmos dump valve?[/quote']I seam to remember a thread on those issues a while back, with the same video.Have you plumbed the fpr in correctly?Well I have one fuel hose connected to the fpr then that hose comes back out into the fuel rail. I got a hose connected to the inlet nipple by the throttle body going tto a T piece connecting to fpr and dump valve. Link to post Share on other sites
vr6guy 29 Posted October 12, 2011 Author Report Share Posted October 12, 2011 So you appear to have no boost reference line connected to the waste gate?The EVAP connection on the manifold open to atmosphere' date=' and a dump to atmos dump valve?[/quote']Is the evap connection on the bottom right of the manifold? I have got a boost controller coming on order, I connect that to the waste gate I think? Link to post Share on other sites
legvw 0 Posted October 12, 2011 Report Share Posted October 12, 2011 So you appear to have no boost reference line connected to the waste gate?The EVAP connection on the manifold open to atmosphere' date=' and a dump to atmos dump valve?[/quote']I seam to remember a thread on those issues a while back, with the same video.Have you plumbed the fpr in correctly?Well I have one fuel hose connected to the fpr then that hose comes back out into the fuel rail. I got a hose connected to the inlet nipple by the throttle body going tto a T piece connecting to fpr and dump valve.Make sure the fpr is on the return side of the fuel flow out of the rail. The fpr needs a take off on the manifold, after the t/b, the original take off is by the coilpack, right side of the inlet, above the servo take off. Link to post Share on other sites
paceo 22 Posted October 12, 2011 Report Share Posted October 12, 2011 you only down the road from me! Link to post Share on other sites
vr6guy 29 Posted October 13, 2011 Author Report Share Posted October 13, 2011 So you appear to have no boost reference line connected to the waste gate?The EVAP connection on the manifold open to atmosphere' date=' and a dump to atmos dump valve?[/quote']I seam to remember a thread on those issues a while back, with the same video.Have you plumbed the fpr in correctly?Well I have one fuel hose connected to the fpr then that hose comes back out into the fuel rail. I got a hose connected to the inlet nipple by the throttle body going tto a T piece connecting to fpr and dump valve.Make sure the fpr is on the return side of the fuel flow out of the rail. The fpr needs a take off on the manifold, after the t/b, the original take off is by the coilpack, right side of the inlet, above the servo take off.Ok will check that, so do I have the vacuum pipe coming of the bottom right hand side of the manifold? Link to post Share on other sites
vr6guy 29 Posted October 13, 2011 Author Report Share Posted October 13, 2011 you only down the road from me!Really! Where bouts are you? Link to post Share on other sites
paceo 22 Posted October 13, 2011 Report Share Posted October 13, 2011 you only down the road from me!Really! Where bouts are you?west wickham mate by the ford garage! got to sort the vr6 at the moment as i think the alternator has gone! Link to post Share on other sites
vr6guy 29 Posted October 14, 2011 Author Report Share Posted October 14, 2011 you only down the road from me!Really! Where bouts are you?west wickham mate by the ford garage! got to sort the vr6 at the moment as i think the alternator has gone!Oh not good! Is that garage by the traffic lights? Take my number mate, 07539938326 Link to post Share on other sites
paceo 22 Posted October 15, 2011 Report Share Posted October 15, 2011 you only down the road from me!Really! Where bouts are you?its the ballam ford garage on corkscrew hill mate :-)west wickham mate by the ford garage! got to sort the vr6 at the moment as i think the alternator has gone!Oh not good! Is that garage by the traffic lights? Take my number mate' date=' 07539938326[/quote'] Link to post Share on other sites
vr6guy 29 Posted October 18, 2011 Author Report Share Posted October 18, 2011 you only down the road from me!Really! Where bouts are you?its the ballam ford garage on corkscrew hill mate :-)west wickham mate by the ford garage! got to sort the vr6 at the moment as i think the alternator has gone!Oh not good! Is that garage by the traffic lights? Take my number mate' date=' 07539938326[/quote']ah yeh i know, next to sparrows den isnt it. Link to post Share on other sites
