justarn 0 Posted October 27, 2011 Report Share Posted October 27, 2011 hey all, need some help i was out and about the other night and my mk1 vr6 cut out and died.have spark but no fuel my fuel pump relay is working but the ecu fuel pump control wire is not doing its job. when i earth the ecu fuel pump pin on the relay and the pump is pumping, you can hear it, she still wont start tho....any ideas? when i turn the ignition on the throttle body buzzes for a bit too, so am i right in thinking the ecu is still alive?What about the crank sensor?im not to good at this stuff any help much appriciated?one thing i dont have a diognostic port either :-( Link to post Share on other sites
