sharky_70 0 Posted November 14, 2011 Report Share Posted November 14, 2011 will a VR6 mocal kit, specifically sandwich plate and extension tube, fit onto a R32 engine? Link to post Share on other sites
sharky_70 0 Posted November 16, 2011 Author Report Share Posted November 16, 2011 anyone? the kit i have now uses a thermostatic plate, extended tube and retains the stock heat exchangercould i use the same kit on an R32? Link to post Share on other sites
FishWick 21 Posted November 25, 2011 Report Share Posted November 25, 2011 Why don't you just try it? You'll soon get your answer.Technically the R32 and 12V blocks are completely different, but the OE heat exchanger fittings are the same, so your Mocal will probably work.Do you actually need it though? My R32 uses the 12V heat exchanger and it the oil and water don't get anywhere near as hot as the 12V used to. Link to post Share on other sites
sharky_70 0 Posted November 25, 2011 Author Report Share Posted November 25, 2011 dont have a spare r32 kicking about unfortunatelyjust planning ahead! Link to post Share on other sites
craggsy 91 Posted November 25, 2011 Report Share Posted November 25, 2011 I've hit bug temps in my R32T on track so will probably go down the oil cooler route soon. Then blank it completely off for daily driving as they don't run hot at all Link to post Share on other sites
FishWick 21 Posted November 25, 2011 Report Share Posted November 25, 2011 Really? My oil hasn't gone over 80 deg yet! I'm using the VR6 sensor screwed into the auxillary output on the R32 oil filter housing.Summer and tracks will be different though I expect! Link to post Share on other sites
FishWick 21 Posted November 25, 2011 Report Share Posted November 25, 2011 dont have a spare r32 kicking about unfortunatelyjust planning ahead!Is it going into a MK2 / MK3? If so, you'll need to drastically modify the front engine mount to make room for it all.Are you turboing it? If not, the OE cooler is plenty I reckon. Link to post Share on other sites
sharky_70 0 Posted November 25, 2011 Author Report Share Posted November 25, 2011 should it happen itll be mk3 and n/aif its not needed i wont run it to save on hassleanyway plans might be a changin if something ive spotted comes off as i hope! Link to post Share on other sites
craggsy 91 Posted November 25, 2011 Report Share Posted November 25, 2011 My temp gauge is in faranheit ahitches to 300 which is about 140-150c and has hit that but does cool down after a cool down lap so not mega hot Link to post Share on other sites
