it wont be from a mk4 golf as they use a different setup, what it will be is a kit from somewhere like R-click. who supply a remote c/l kit and instead of a separate fob, it has a key fob with a switchblade identical to the mk4 , look inside your boot ,behind the right hand side carpet just below the light,there will probably be a little black box linked into your standard vacuum pump wiring, just unplug the loom and swap over, hey presto you have a mk4 fob and remote locking. then you need to go on te companys web site to get a blank mk3 key blade and have it cut by any locksmith etc . hope this helps
