VR6 DUBBER 0 Posted November 22, 2011 Report Share Posted November 22, 2011 Starts first timeLeave it runTurn it off Then will not start againHear humming noise from throttle body is this normal ?Notice that the auto choke cuts off after warm and then have the starting issue Link to post Share on other sites
VR6Pete 1,455 Posted November 22, 2011 Report Share Posted November 22, 2011 Could be your poss blue temp sensor.. assuming your letting it get upto temp on the first start... how long are you leaving it to run and turn off?humming noise is normal if you have OBD2, theres a little stepper motor in there Link to post Share on other sites
VR6 DUBBER 0 Posted November 22, 2011 Author Report Share Posted November 22, 2011 1)Thanks will look at blue if unplug will it still run ?2) The vagcom is only communicating with ABS controller the rest say no response3) Really would welcome your help on gettiing to the bottom of my issue would you be willing to keep posting to help me fix...thanks Link to post Share on other sites
