cliveyp 0 Posted March 8, 2005 Report Share Posted March 8, 2005 Spent the afternoon getting the nice shiney manifold on until i started to struggle with a tight bolt. I noticed that as i was pulling on the ratchet, the engine was moving a fair old amount. Thought to myself that something ain't quite right about it so i investigated further. Gearbox mount is completely shot. The bolt isn't holding anything at all, so that end is just waving about in thin air!Awkward job to do?? Link to post Share on other sites
VR6Pete 1,455 Posted March 8, 2005 Report Share Posted March 8, 2005 from what i beleive, the gearbox mount is one of the easiest ones to do! Link to post Share on other sites
Peakz 0 Posted March 8, 2005 Report Share Posted March 8, 2005 Block of wood and No Nails'll do the trick surely?! Link to post Share on other sites
acf8181 0 Posted March 8, 2005 Report Share Posted March 8, 2005 from what i beleive' date=' the gearbox mount is one of the easiest ones to do![/quote']depends if you can raise the engine enough to pull it clear (without risking your exhaust and other mounts....you'd be best unbolting front mount as well). if not, its the hardest. the bracket is a pain to get off (tip, go under the wheel arch) Link to post Share on other sites
dubloke 4 Posted March 9, 2005 Report Share Posted March 9, 2005 i had mine changed when i my quaife'd box went in as we snapped the original trying to revove it. was fairly easy then but i did have the front end off completely and, as andrew says, the front mount need to be off to to allow you to jack the car up to clear the zorst! should still be fairly straight forward tho! Link to post Share on other sites
cliveyp 0 Posted March 9, 2005 Author Report Share Posted March 9, 2005 Am i right in thinking that the centre bolt is all that holds it all together and to the car?? What does that centre bolt go into?? I'm wondering cos i had thoughts this morning that perhaps its just come undone....... :? I thinking this cos when i wobbled the engine, the bracket obviously moves, the bolt is free too, but the rubber stays where it is........ Link to post Share on other sites
fabio_vr6 0 Posted March 11, 2005 Report Share Posted March 11, 2005 2 bolts hold the mount to the subframe then one bolt from the engine bracket to the mount! Link to post Share on other sites
cliveyp 0 Posted March 11, 2005 Author Report Share Posted March 11, 2005 The stealers has just rang to say the mount has arrived. Will have an eventful time getting the little fecker on now! Link to post Share on other sites
stu h 0 Posted March 11, 2005 Report Share Posted March 11, 2005 good luck mate. did they want an arm and a leg for the part? Link to post Share on other sites
cliveyp 0 Posted March 14, 2005 Author Report Share Posted March 14, 2005 Only 48 quid for a genuine item so i ain't that phased. Got it on now and it feels much better. Just gotta sort the front mount with a VT one when i've got the spare money now!! Link to post Share on other sites
VR6Pete 1,455 Posted March 15, 2005 Report Share Posted March 15, 2005 the VT's were only £60 quid last month Link to post Share on other sites
badboyV6 4 Posted March 15, 2005 Report Share Posted March 15, 2005 the VT's were only £60 quid last month Front ones???? %-6 Link to post Share on other sites
MrsC 0 Posted March 15, 2005 Report Share Posted March 15, 2005 u missed out on a 20% discount Link to post Share on other sites
badboyV6 4 Posted March 15, 2005 Report Share Posted March 15, 2005 Gutted!!! :-( Link to post Share on other sites
binliner 0 Posted March 15, 2005 Report Share Posted March 15, 2005 £60 doesnt sound right for 20% off a front mount? Link to post Share on other sites
badboyV6 4 Posted March 15, 2005 Report Share Posted March 15, 2005 Thats what i thought- maybe for a gearbox mount????? Link to post Share on other sites
cliveyp 0 Posted March 16, 2005 Author Report Share Posted March 16, 2005 the VT's were only £60 quid last month All well and good, but mine hadn't gone last month! Link to post Share on other sites
