lumoxs 0 Posted December 11, 2011 Report Share Posted December 11, 2011 As above guys really, what's the specs of the turbos using?For example:Model - T3AR Compressor - 50mmAR turbine - 50mmEtc etc, just wanna get a rough idea of the specs of the turbos you guys are using so I know what to roughly go for...Really thinking T3 turbo but there's to many cheapy turbos around to trust to be honest Cheers y'all Link to post Share on other sites
jims13 6 Posted December 11, 2011 Report Share Posted December 11, 2011 a t3 based turbo will be fine, as i said via pm, stay away from t28/t25 .. yoy may pick up a cheap holset hx40 ? or if not grab a t3 with a large ish a/r and compressor.google some compressor maps to see what does what at which point .stay away from internal wastegate turbo's as these may be to small , although its not a given Link to post Share on other sites
lumoxs 0 Posted December 11, 2011 Author Report Share Posted December 11, 2011 If I can't get a holset turbo?? Wats best after?? Link to post Share on other sites
Daverse 175 Posted December 11, 2011 Report Share Posted December 11, 2011 Garrett probably matey, 35 or maybe 40, depending on when you want your boost / how much e.t.c. Link to post Share on other sites
russj249 2 Posted December 11, 2011 Report Share Posted December 11, 2011 im using a Garrett GT3582R ball bearing turbo.. the 82 is the best for quick spool without running out top end, but again depends if you want it to kick in low down and progressive or high revs like a bomb.Mine starts to build up by 3000 and full 15psi by 3750 - 4000rpm, and very very progressive, so much that even with 360bhp without a LSD, it will accelerate full throttle in 3rd in the pouring rain without spinning one bit. Link to post Share on other sites
lumoxs 0 Posted December 11, 2011 Author Report Share Posted December 11, 2011 I dont wanna run loads of boost and fubard my internals etc deffo lookin at gettin a T3 turbo then for sure deffo Link to post Share on other sites
lumoxs 0 Posted December 11, 2011 Author Report Share Posted December 11, 2011 Or go for the garrett and get the boost lower down the rev range Link to post Share on other sites
VeedubVR 0 Posted December 13, 2011 Report Share Posted December 13, 2011 after talking to a few guys they said that if you map a GT35 it will be quite laggy if you keep stock internals, with stock capable of 400ishThere's a guy on vwvortex running 550bhp on stock internals with just a head spacer plate. I know these engines can take serious power but will tend to brake shafts quite often with alot of low down power Link to post Share on other sites
craggsy 91 Posted December 13, 2011 Report Share Posted December 13, 2011 Im sure mine has a GT30 hybrid on it tho cannot be 100% sure on it as cant see the turbo lol Link to post Share on other sites
russj249 2 Posted December 13, 2011 Report Share Posted December 13, 2011 I don't find I have much lag at all with GT35 on standard internals, and the bit that there is means its perfect to drive around town without coming on boost, but there when you want it.. I'm makin 180 bhp (which was my max power before turbo at 5500rpm) at 2500rpm, so anythin up from there is all smiles!!I have never been to any shows but maybe you could blag a lift in one to see what you think? Too much power low down kills gearboxes and clutches, but a nice progressive power delivery higher up the rev range is better on everything. Link to post Share on other sites
jims13 6 Posted December 14, 2011 Report Share Posted December 14, 2011 a small ar will kill your box .. go for a larger one.. no point in losing trq, if your capable of holding it to redline . Link to post Share on other sites
MaidenVR6 26 Posted December 19, 2011 Report Share Posted December 19, 2011 I use a Garrett GT35R T3 ar/1.06 Full boost or 30 psi at 3800 rpm. Its a very nice turbo, with plenty off power and when not in boost, the car pulls better than stock. And all hell braks loose from 3000 and up.Doesnt matter what gear im in.If I was to choose again, it would have been a Precision 6765 T4 0.81 or something in that direction.6262 T4 0.81 should be a very nice 12V Turbo.It all depends on how much power you want.Dont not get a smaller T3 housing than 0.82I 4-5 years ago I used T3 0.63, and it maxed out at 5500 rpm. Link to post Share on other sites
