Dragon Dave 1 Posted December 12, 2011 Report Share Posted December 12, 2011 I'm looking into a 6 speed gearbox conversion for my mk3 VR6.So far using the search, I have found some info saying that I need an O2M gearbox from a 2.8 V6 4motion.On the VWVortex forum, I find a thread about the O2M gearbox, it says the one to get, is the DRP from a 1999-2000 2.8 4motion Golf/Bora.I'm a little confused, are both of these codes (O2M & DRP) for the same box?If I find a gearbox for a 2001 Golf/Bora 2.8 V6 4motion with the code DRP, is this the box I want? Or do I need to check if it is an O2M?Are there any other choice of 6 speed box's? Is this the best one to get?Any help would be great thanks,Dave Link to post Share on other sites
ralf 0 Posted January 2, 2012 Report Share Posted January 2, 2012 The easiest solution is made ​​by EuroTuning http://www.eurotuning.cz/images/file/conversion_kit.pdf Link to post Share on other sites
Dragon Dave 1 Posted January 2, 2012 Author Report Share Posted January 2, 2012 Thanks for your reply Link to post Share on other sites
VIW28 29 Posted January 2, 2012 Report Share Posted January 2, 2012 02M is the family namel of box, DRP is the specific model. Fair bit of expense and work to do it right as you'll probably want to do away with the dual mass flywheel it's supposed to run with Link to post Share on other sites
razzor 0 Posted January 28, 2012 Report Share Posted January 28, 2012 anyone try the 02S 6speed from the Golf 5 ?Im busy fitting a 6 speed GQP just battling to find a selector for it. Link to post Share on other sites
