right guys heres something a few certain members might be able to help me with.
on Caddyslammed`s candy white vr6 , he has an OBD1 Loom, he sourced an obd2 loom from a 1997 P reg vento vr6.
looms all connected etc , apart from a few differences with fan connectors. BUT there are a couple of plugs that even i am unsure of! they are inside the vehicle , and im pretty sure the big black plug is comething to do with headlights. but would appreciate any input from others.
any ideas?
sorted guys. bit of etka research shows that the 12pin black plug is for vehicles fitted with airconditioning. so we wont be needing it anyway ;) the other 2 plugs are to do with air conditioning aswell. so all is well :) cheers for the input guys
Great job mate thanks, just need to find out now if this causes any normal fan running implications?? :)
  • 3 weeks later...
Hi, I've been doing some work this week with a new loom for my golf and I I have a feeling the plugs you have shown are all connected with the aircon, I noticed you have quite a thick red/black power cable leading to the yellow plug, I noticed this was thicker on my loom for climate control, is that a possibility?
You mention you found out what the other plugs are for actually, what is the green single pole plug for as mine is currently dangling?
if you look at the front page of the electrical threads, there is a complete mk3 fusebox Diagram that i posted. the thicker cable leading to the yellow plug, is indeed for aircon. the difference is weather its just air con or if it has complete climate control . the little green plug, similiar to the white plug, both with red and black cable leading to them are left disconnected. i cant remember off the top of my head what they are for unfortunately.
