hi im building a track car and have put on braided hoses and bleed the brakes i bought the software from gendan to use on my laptop to do all the fault codes etc and followed the system to bleed the abs system but now when i touch the brake pedal a buzzer sounds and the side light come on this did not happen until i had bleed the brakes has anybody got any idears what the problem is we have pulled through two litres of brake fluid thanks
the flying plumber
The side light comes on? Sounds more like an earth fault or wrong bulb on the back light, and when the brake light comes on its powering the side lights too, which with the door open would buzz? does is still buzz when the drivers door is fully shut? Can't see how it would do it though.
