Pearsy47 1 Posted January 3, 2012 Report Share Posted January 3, 2012 Hi people the steering in my mk3 is poo ! when i put my foot on the brake the steering does its own thing im always fighting it ! i know that my tracking is off due down to my tyres going right down to the mesh ! on one side ! i don t know what else apart from tracking could i check or sort out or i dunno but if anyone has got any advice please feel free ! thanks steve Link to post Share on other sites
Pearsy47 1 Posted January 3, 2012 Author Report Share Posted January 3, 2012 and also if anyone could reconmend some tyres at the min i have the toyo prada spec 2 but i seem to wear out too quick ! Link to post Share on other sites
Ben Seabrook 4 Posted January 3, 2012 Report Share Posted January 3, 2012 get the tracking and tyres sorted before you mess with anything else mate as that is the most likely cause Link to post Share on other sites
Pearsy47 1 Posted January 3, 2012 Author Report Share Posted January 3, 2012 get the tracking and tyres sorted before you mess with anything else mate as that is the most likely cause thanks that what im going to do just woundered what else could it be ! Link to post Share on other sites
Ben Seabrook 4 Posted January 3, 2012 Report Share Posted January 3, 2012 wishbone bushes, alignment, steering rack ! all sorts but you have an obvious culprit already as for tyres not sure as I always use the toyo t1r's but they are soft too Link to post Share on other sites
Pearsy47 1 Posted January 3, 2012 Author Report Share Posted January 3, 2012 wishbone bushes' date=' alignment, steering rack ! all sorts but you have an obvious culprit already as for tyres not sure as I always use the toyo t1r's but they are soft too[/quote']lol well i shall get tracking sorted and see how much out they are lol and tyres such a pain because all i keep on finding are the soft com tyres go cheaper yea maybe harder but will there be any grip ! lol all i know its between the toyos or yokos ! Link to post Share on other sites
oldmandon 1 Posted January 3, 2012 Report Share Posted January 3, 2012 How much are you looking to spend on tyres? look at Goodyear Mitchlen or Perelli . slightly lower down Maxxis Federal etc Link to post Share on other sites
craggsy 91 Posted January 3, 2012 Report Share Posted January 3, 2012 Buy tyres before doing any geometry setups tho Link to post Share on other sites
Pearsy47 1 Posted January 4, 2012 Author Report Share Posted January 4, 2012 How much are you looking to spend on tyres? look at Goodyear Mitchlen or Perelli . slightly lower down Maxxis Federal etc i don t mind as i had a look on black circles and for my yoko's it would be for 2 fitted £120 i did look for other tyres just want some abit more harder wearing but at the same time i don t wanna loose grip ! Link to post Share on other sites
Pearsy47 1 Posted January 4, 2012 Author Report Share Posted January 4, 2012 Buy tyres before doing any geometry setups thoso before i get the motor tracked i should get my tyres done !? Link to post Share on other sites
oldmandon 1 Posted January 4, 2012 Report Share Posted January 4, 2012 if its tracking you're having adjusted, I would do it at the same time, as all the tracking does is put it back in line. Potholes are good for knocking it out. I'm not sure, but I think Craggsy was on about more in-depth stuff like rake, toe in and out camber etc. Tracking would be fine and cheap. Link to post Share on other sites
Pearsy47 1 Posted January 4, 2012 Author Report Share Posted January 4, 2012 ah ok then its just at time it really feels like the steering wheel is not connected at all !! which does shit me up abit i just want it back to sodding normal lol Link to post Share on other sites
Lukey. 381 Posted January 4, 2012 Report Share Posted January 4, 2012 if it doesnt feel connected at all id be having a look at the bushes and stuff like track rod endsjack it up and grab the front wheel at 12oclock and 6 and rock it for up and down play, then do the same at 9 and 3 for side to side play, for each side.as craggsy said if youre gonna buy new tyres anyway get them fitted first and then get the alignment changes done asap after theyre fitted, as you dont want the new tyres to wear into the current setup then youll have the same problem all over next time you buy tyres again Link to post Share on other sites
Pearsy47 1 Posted January 5, 2012 Author Report Share Posted January 5, 2012 if it doesnt feel connected at all id be having a look at the bushes and stuff like track rod endsjack it up and grab the front wheel at 12oclock and 6 and rock it for up and down play' date=' then do the same at 9 and 3 for side to side play, for each side.as craggsy said if youre gonna buy new tyres anyway get them fitted first and then get the alignment changes done asap after theyre fitted, as you dont want the new tyres to wear into the current setup then youll have the same problem all over next time you buy tyres again[/quote']ok but i thought a MOT person would have check the wheels like that ? and at the min ive got some part worn tyres on becuase of the tracking issuse i was going to get it tracked with the part worns on then get new tyres. Link to post Share on other sites
Pearsy47 1 Posted January 5, 2012 Author Report Share Posted January 5, 2012 if its tracking you're having adjusted' date=' I would do it at the same time, as all the tracking does is put it back in line. Potholes are good for knocking it out. I'm not sure, but I think Craggsy was on about more in-depth stuff like rake, toe in and out camber etc. Tracking would be fine and cheap.[/quote']thanks for the advice just want the car to drive straight its a pain when you wanna drive up to 70mph and the steering wheel has a mind of its own lol Link to post Share on other sites
Pearsy47 1 Posted January 5, 2012 Author Report Share Posted January 5, 2012 i just had the tracking done and one wheel was out by 12mm which the bloke said thats not normal lol and she now drives abit better just see how it goes getting home ! thanks for everyone advice !!! Link to post Share on other sites
