vf charger fitment.
dont really want the turn it as you want the return to flow down not up and then down again ..... what paul said should work best if not adjust the leg with a BIG hammer .....
I might have use a big hammer!! thank you for all help guys
Im running a v2 charger , had to drill a hole in the chassis leg . simple to do and you can get it nice and clean if you line it up nice the first time . Dont forget to leave room for some movement for when you tension the belt . I made that mistake and had to make the hole wider for it to clear when tensioning the belt .
Im running a v2 charger ' date=' had to drill a hole in the chassis leg . simple to do and you can get it nice and clean if you line it up nice the first time . Dont forget to leave room for some movement for when you tension the belt . I made that mistake and had to make the hole wider for it to clear when tensioning the belt .
Thanks have you got any pictures of it?
