philboyvr6 0 Posted March 13, 2005 Report Share Posted March 13, 2005 Hi AllI have removed the head from my 1993 VR6 (water seeping form the back of the head gasket) and have found that some of the lining material on the tensioning blade has broken away, therefore, I need to replace the complete blade.My problem is I cant see an easy way of removing it. Do I need to remove the gearbox to get access to the cover remove the cover and then slide the blade out, or is there an easier way?Can anyone tell me how to do the replacement?Thanks Link to post Share on other sites
acf8181 0 Posted March 13, 2005 Report Share Posted March 13, 2005 yep, gearbox has to come out.....so you may as well replace the lot if you do that (about £100 for all the parts, from gsf - and they're o.e. parts).its always the blade runner that goes first. Link to post Share on other sites
philboyvr6 0 Posted March 13, 2005 Author Report Share Posted March 13, 2005 Thanks acf8181 you comfirmed the bad news (I could see no other way of doing it).Does anyone know of any special tools that are needed or anything else that I should know?Are there other threads that might help? Link to post Share on other sites
trackman 0 Posted March 13, 2005 Report Share Posted March 13, 2005 Amazing detailed procedure here.http://forums.vwvortex.com/zerothread?id=1264409Rich Link to post Share on other sites
acf8181 0 Posted March 13, 2005 Report Share Posted March 13, 2005 only other thing to be aware of is that if your clutch is quite worn its the perfect time to change it (get one from vw, only about £80 and good quality). though mine still has plenty of life left after 120k (is deffo original as well, has date stamp on it!)oh, you must use new flywheel stretch bolts as well (trust me you dont want the flywheel to break free...have heard of people loosing feet with it happening) Link to post Share on other sites
philboyvr6 0 Posted March 15, 2005 Author Report Share Posted March 15, 2005 TrackmanThanks for the link to the thread, excellent detail, it will be a great help.CheersPhilboyvr6 Link to post Share on other sites
trackman 0 Posted March 15, 2005 Report Share Posted March 15, 2005 No probs Phil, I got it off a thread on here a few weeks back.Yeah forgot about those bolts acf. Just got some in. Not worth the risk as you say.Rich Link to post Share on other sites
