Walbro fuel pump question
I'm thinking of buying one of these (the GSS430 seems to be the recommended model) but have read differing opinions regarding whether it is necessary to keep the tank above 1/4 full. That would be doable but a bit of a hassle and I would find myself always worrying about running too low going round a left hand bend (perhaps in a 'spirited' fashion) and starving the pump and risking it burning out.
I've looked at a few threads where people say it should be mounted low in the swirl pot and I'm sure I could manage that - I've currently got a spare pump in pieces on the bench and it looks reasonable enough - but would that be enough?
Any thoughts / reassurance would be welcomed!
Cheers for your time...
When I fitted my HRC performance fuel pump, I had this issue.. basically anywhere close to the red on gauge and going round a slow right hander, like a 90 degree junction type thig, it would stutter, took me a while to work out as when it stuttered you try to stop it cutting out with more accelerator, yet this just made it use the remaining fuel quicker and would just clonk out. When it stuttered and i don't touch pedals, pressure used to build back up better and would carry on running.
Basically as Paul has said, if it ever did this at full revs having a play with someone, somethings going to go wrong soon enough. If I was you, I would take Paul's swirl pot to make sure this doesn't happen.
^^^^ Same here!
My new setup will be using an 034 Motorsport FP34 swirl tank with 044 pump. Ive tried the Walbro, the external 044 and finally the in tank HRC. First two were noisy and the last one you had to keep minimum of 1/4 tank.
Don't the walbro's have a little spout at the bottom? Mine is kind of flush, but only to the mesh that the standard pump sucks from?
Also my HRC one is silent, especially for 255lph I'd say its quieter than the standard pump, but even with a modified adapter to fit it directly into the standard pump housing etc it still don't like under 1/4 of a tank.
Just to clarify, it's the GSS340 you need, not 430 ;-)
Even mounted right at the bottom of the pump housing it will still surge. I've been using them for years and not yet come up with a solution for it.
It's quite simple really. Walbro need to replicate the OE pump's return system, but they won't for what ever reason. The OE pump has a feed from the return swirl pot directly into the pump head. The Walbro does not, which is why it surges.
Brilliant! Thanks everyone for all the genuinely helpful replies. Suppose I'll just have to get used to the idea of keeping topped up...
First five replies within a couple of hours of posting - feels good to be part of this community!
