palmer 17 Posted February 13, 2012 Report Share Posted February 13, 2012 Hi all, Hopefully someone here can help me. I have been having issues every now & then with regards to gettin the car in gear. Sumtimes its abit hard to engage well that has now got worse as the car has decided its going to get stuck in 4th !! I dont no wat could have caused this as im not 100% with gearboxes.....Any help would be ideal as it is a daily so need it alive again asap.Cheers Ps- Its a standard 93 vr6 gearbox. Link to post Share on other sites
craggsy 91 Posted February 13, 2012 Report Share Posted February 13, 2012 Does it go into gears using the weight on the gearbox itself Link to post Share on other sites
palmer 17 Posted February 13, 2012 Author Report Share Posted February 13, 2012 The weight is moving round an it feels like its locking into a couple of gears but dont think its doing all of them (Although i could be wrong) Link to post Share on other sites
cabrioman 6 Posted February 13, 2012 Report Share Posted February 13, 2012 can you select any gear without the engine running ???? how does the clutch feel ???? Link to post Share on other sites
palmer 17 Posted February 13, 2012 Author Report Share Posted February 13, 2012 Clutch feels fine. Cant engage any gears the stick jus feels floppy and unresponsive..... Link to post Share on other sites
cabrioman 6 Posted February 13, 2012 Report Share Posted February 13, 2012 check the connections for the cables on the turret on top of the gearbox make sure they are ok, check the counter weight is secure and check inside the car the connections on the gear stick .... Link to post Share on other sites
rodney 17 Posted February 13, 2012 Report Share Posted February 13, 2012 you are looking for two things as the chaps are infering... is the gearbox staying where it should and/or are the movements you make on the stick being transferred...So as above look at the item Tony mentions as he is the expert here Link to post Share on other sites
palmer 17 Posted February 13, 2012 Author Report Share Posted February 13, 2012 Cheers lads will check them out 2mura. Hopefully will be that an not something more sinister Link to post Share on other sites
palmer 17 Posted February 25, 2012 Author Report Share Posted February 25, 2012 Ok so finally got round to checking and found problem, thats now sorted but i have lost 2nd gear !! The weight lifts to go into second but there is no movement to allow it in to gear....... ?? Any ideas lads Link to post Share on other sites
palmer 17 Posted March 11, 2012 Author Report Share Posted March 11, 2012 Ok so sorted it the 1st time the bush had come out of the cable, did it again on route to UD then the weight snapped off. will source weight 2mura but does any1 no where to get hold of new gear cables ?? an also possibly a throttle cable ?? Link to post Share on other sites
cabrioman 6 Posted March 11, 2012 Report Share Posted March 11, 2012 throttle cable should be able to get from Euro Car Parts or GSF as for cables ill check ebay and some one breaking a vr mate .... Link to post Share on other sites
palmer 17 Posted March 11, 2012 Author Report Share Posted March 11, 2012 ok cheers m8 wernt sure if u could get the gear cable new from anywhere ?? If not no worries i will raid the vr down the local scrappy lol Link to post Share on other sites
