is it worth using shell optimax
Well the VW/Audi specialist i deal with tell me not to use anything else- (mind you my cars chipped) It is expensive though. I think there is a difference - the car feels more responsive. Ive been using 97 RON super unleaded too. I suppose it depends on how flush your feeling.... It doesnt do any hard using normal unleaded.
Sorry, I know I'm dragging this up after a few days. Don't believe the hype.
Higher octane levels in fuel allow you to run a higher compression ratio without getting knocking (partial fuel combustion). Highly tuned engines tend to run high compression ratios, thus needing high-octane fuel.
The VR6 runs 10:1, not particularly high. I use 95 RON in mine and I don't get any knocking, so there's no advantage in me using higher octane fuel. There's nothing in it to actually produce more power.
thanks for the help. went to motorsport developments they re -mapping specialist they told me to use shell optimax and take my k&n induction
kit off and put the original air box back on they are specialist in live mapping
www.motorsports-developments.co.uk
plmk is a good thing or a bad one
thanks tinny22
It only costs about 4p a litre more' date=' if you put in 40 litres, that's just an extra £1.60. I'm quite happy to pay that knowing my car's running on the best fuel available.
well said but i think that texico superplus is better (optimax loses octain as sits in tank )
Back on the Optimax subject, Evo mag did a 1000 mile test on 3 different cars a couple of years ago and recorded tiny improvements in performance on all 3.
The real advantage was that Optimax contains a cleaning agent and photos of the valve backs and piston crowns showed a marked reduction in carbon deposits after using Optimax. It seemed to actually get rid of most of the build up of gunk in all 3 engines.
I've used it ever since.
