Vr9k 0 Posted February 20, 2012 Report Share Posted February 20, 2012 when fiddling with my brakes the other day i lost a bit of fluid, after i reassembled everything my brakes were sh*te resulting in pedal to the floor which just slow me down not stop. After going up and down the road slowly hoping they would fix themselves, lol they didn't. Then my clutch went, i cant engage any gear when running. So there it has sat since.Awaiting a mate to bring home a brake bleeder from work, we shall be running this through and changing fluid at the same time. So just wondering if anyone knows if these symptons are the cause of the clutch problem and if once bleed and fluid levels back to normal all will be ok?????i just want it to be a simple fix otherwise i lose all interest and itll sit there for quite sometime Link to post Share on other sites
Daverse 175 Posted February 20, 2012 Report Share Posted February 20, 2012 Yup sounds like you need to bleed your brakes, and dont forget to bleed the clutch as well Link to post Share on other sites
bethslad 1 Posted February 20, 2012 Report Share Posted February 20, 2012 Hello mate Yip its sounding like you need to bleed the whole system, i had the same problem with my car after replacing the rear calipers, but after bleeding the brakes again and the clutch all was good again, Just remember to bleed them in the right order, furthest away from the reservoir first then the next furthest away and so on, you probably already knew that though hope it all goes well Link to post Share on other sites
Vr9k 0 Posted February 20, 2012 Author Report Share Posted February 20, 2012 ok cheers guys, my knowledge is a bit thin but growing as & when something needs fixing haha. My mate's an Audi technician @ the local dealers, im the goffa. How is the clutch bled then, where's the bleed nipple.....down near the pedal box or in the bay somewhere ? Link to post Share on other sites
ashmk3 0 Posted February 20, 2012 Report Share Posted February 20, 2012 Bleed nipple on the cylinder on the gear box Link to post Share on other sites
Vr9k 0 Posted February 20, 2012 Author Report Share Posted February 20, 2012 Thanks again, nice quick replies :-) Link to post Share on other sites
