Guest keiichi Posted March 20, 2005 Report Share Posted March 20, 2005 Cheap kit but... Ok so I've got a couple of niggling starting issues... I went out and picked up a Gunson error checking tool. The box stated it supports passat VR6 from 93 - 96.. I assume this will work on my 95' Corrado with OBD1. The kit comes with x3 spades of which you can insert into the connector beside the gearstick.. ah ha.... the diagram is different.. I have a block with two rows ... 3 out of each row have wires coming off of them... the Gunson kit has a Yellow, Blue & Red wire than you insert.... somewhere... NEED to get this sorted.... need help on this, please!!So..1. Can I confirm what the connector is I have?2. Anyone used the Gunson kit to check error codes? &| Link to post Share on other sites
cliveyp 0 Posted March 20, 2005 Report Share Posted March 20, 2005 Dunno if this is any help, but the later Rado's, although being OBD1, have an OBD2 style connector...................... Link to post Share on other sites
