malcolm 0 Posted March 20, 2005 Report Share Posted March 20, 2005 My car runs at between 60 and 70 degrees , goes up to 80 if pushing it. I would have thought it should be higher than this. Any ideas, what temp does your car run at. Link to post Share on other sites
goodboy1451 0 Posted March 20, 2005 Report Share Posted March 20, 2005 mines typically runs at 92-96'C. When pushed to 100mph on the moptorway, the temperature can rises to 102-104'C. Link to post Share on other sites
badboyV6 4 Posted March 20, 2005 Report Share Posted March 20, 2005 Ive seen mine touch 100 once. Usually 96- 98. Strange but since using a thicker oil in my VR 15W 40- the oil temperature has gone up. When i was using Castrol RS 0w 40 oil temp never went higher than 86!!! Link to post Share on other sites
AntWhiting 0 Posted March 20, 2005 Report Share Posted March 20, 2005 if im not pushing the engine then somewhere between 75-85'C, if im pushing the engine that little bit more 85-100'C.I do have a coolant problem though! Link to post Share on other sites
malcolm 0 Posted March 20, 2005 Author Report Share Posted March 20, 2005 badboy, I am talking water temperature Link to post Share on other sites
binliner 0 Posted March 20, 2005 Report Share Posted March 20, 2005 That sounds low for water... when up to temp mine sits slap bang in the middle of the dial (90) and stays there Link to post Share on other sites
stu h 0 Posted March 20, 2005 Report Share Posted March 20, 2005 mine sits pretty much exactly on 70, goes up when sitting in traffic, but no further than vertical.and as soon as i start moving it goes back to 70. it had a radiator not long before i got the car. Link to post Share on other sites
cliveyp 0 Posted March 20, 2005 Report Share Posted March 20, 2005 Coolant temp is slap bang on the middle. Never any more! Link to post Share on other sites
Devilfish 0 Posted March 20, 2005 Report Share Posted March 20, 2005 middle always... no matter what im doing... Link to post Share on other sites
malcolm 0 Posted March 20, 2005 Author Report Share Posted March 20, 2005 Thanks for input guys Link to post Share on other sites
badboyV6 4 Posted March 21, 2005 Report Share Posted March 21, 2005 My mistake Malcom- Yep mine sits bang in the middle too, going like a looney or not.... Link to post Share on other sites
fabio_vr6 0 Posted March 21, 2005 Report Share Posted March 21, 2005 That sounds low for water... when up to temp mine sits slap bang in the middle of the dial (90) and stays therethats cus you have a late car! non accurate reading Link to post Share on other sites
malcolm 0 Posted March 21, 2005 Author Report Share Posted March 21, 2005 Fabio, its a 1994. May be the thermostat stuck open Link to post Share on other sites
DundeeDub 0 Posted March 21, 2005 Report Share Posted March 21, 2005 or you have a neuspeed one, my neuspeed one make it sit at 70 if the cars moving at any speed, if in traffic or ery slow it goes up to 90ish Link to post Share on other sites
silverline 0 Posted March 21, 2005 Report Share Posted March 21, 2005 mine sits at about 1/4 when driving 1/2 way when in traffic but no further. when i had a diagnostic tool plugged in the gauge was reading about 60'c but the diagnostic tool said 80'c odd! i dont expect the gauge to be particually accurate but i thought it would be more accurate than that? Link to post Share on other sites
