help needed - can't find correct part for brakes
Hi i bought a vr a couple of months ago that needed some work on it to get it through an mot. one of the failures was the copper brake pipes both sides on the rear were excessively corroded. i've bought these and also replaced the flexi pipes on the calipers as these looked fairly worn, but i also need to replace the flexi pipes that goes from the rear copper line and connects to the next bit of copper. i can post pics if required, they are slightly different from the flexi's on the calipers and i am having great difficulty finding the correct ones if someone could supply a part no. or tell me what part of the brake system these pipes are specifically referred to as, that would be great.
thanks that was the correct part number ,uch appreciated :-) however i came across another problem once it came to bleeding the brakes; the thread on the bleed screw is knackered and nowehre seems to do the bleed screws on their own, i've tried gsf, cas, etc, everyone is trying to flog me the calipers as a hole, does anyone know where i can get the bleed screws from for the rear of the car, and also the front just in case? thanks
