Worst in the world at keeping an up to date build thread! Ayhow, nearly done now, all boost pipes made, driveshafts sorted, wiring done....just turbo oil return and coolant hoses to sort then after an ECU flash shes ready to fire before I make a start on the Haldex...
Have a load more photos but having a few iPhail's of late regards Photobucket and Apps and stuff. :rolleyes:
  • Replies 82
Popular Posts
Ask Paul he blew his intake manifold
  • 1 month later...
Courtesy of United Motorsport my new 24v lump now lives. Couple of niggles to sort before it gets back on it's wheels but hopefully not too much longer. Will update in detail when I get time to write it up but for now here's a few pics and a wee video of it running after initial start.
Couple if engine bay shots from the finished result. Standard inlet will have to do for now but is only temporary.
Just for you Tony! The rad and fan setup works well so far, fan comes on at 70 degrees with no issues. Will have to see how the rad performs in boost and on the road though. It is on there as a trial and if it works any way well I'll be having a custom ally one made for the job with better cooling efficiency.
UM flash, did some security measures in case anyone fancied their chances at stealing my ecu to copy it...
After a few hours of effing about trying to get the ecu to take the flash it turned out to be a silly alarm remote issue preventing it. With that sorted I was never as glad to see this screen!
Short uninteresting video to prove it actually does run lol
Hello m8 this may sound stupid (but hey u gotta ask to learn rite), When you fitted the 24v lump did you have to alter the rear mount as the mk4's run the dog mount ?? Or do the mk3 mounts bolt up to the block ok ??
Any help would be ideal as i shall be droppin my lump in soon when ive pulled it out donor lol,
Cheers m8, Lee
I've used a United Motorsport 02M transmission adapter mount, standard rear 12v mount which bolts straight to 24v block and had to adapt the front engine mount. This is only if you use the 02M 6 speed....most people over here seem to use the 12v 02A box because it all bolts straight up.
If you use the 12v 02A transmission you can use the OE 12v mounts all round. All that's required is a spacer on the top bolt of the front mount.
Craig, think you're thinking of Kristan/Maiden VR6
