yes its the only fluid VW do.
disconnect a hose and let it drain, then rotate the wheel from lock to lock over and over and it will pump more out.
Refilling is the same, pour some in to the fill line then rotate the wheel lock to lock again, top up repeat until the system is full then turn it on and do lock to lock again until it is fully bled
