vdubtomo 0 Posted April 10, 2012 Report Share Posted April 10, 2012 Ok so after deciding to remove my gearbox to get it reconditioned i have decided to put a 3.64 final drive and bolt kit into the mix!Iv been told that a mk3 16v has the final drive that im after, is this true? Link to post Share on other sites
oldmandon 1 Posted April 10, 2012 Report Share Posted April 10, 2012 I thought it was the Corrado G60 final drive you needed??!! may be wrong, ask VRPETE he knows. Link to post Share on other sites
craggsy 91 Posted April 10, 2012 Report Share Posted April 10, 2012 I know the 16v ABF has a different ratio that works but can't remember what it is Link to post Share on other sites
michael5556 247 Posted April 10, 2012 Report Share Posted April 10, 2012 I always thought it was g60 final drive that was the more suitable one. Link to post Share on other sites
VR6Pete 1,455 Posted April 10, 2012 Report Share Posted April 10, 2012 You need a 3.68 final drive from a g60. 16v is to short..You also need ARP bolts to replace the factory fitted rivets. Just about to do mine at the mo Link to post Share on other sites
oldmandon 1 Posted April 10, 2012 Report Share Posted April 10, 2012 Saying that though when I think about it, someone also mentioned the final drive out of the 1.9TDi. But I was going to use the G60 when I get round to doing it!!!! Link to post Share on other sites
craggsy 91 Posted April 10, 2012 Report Share Posted April 10, 2012 Right im on laptop now so here goes.3.64 FD is from a CDM corrado VR6 box3.68 FD is from a CDA golf gti 16v3.68 FD is from AYL/AYK Corrado G60 and Passat 16v.just for some ideas Link to post Share on other sites
oldmandon 1 Posted April 10, 2012 Report Share Posted April 10, 2012 So whats the diesel final drive? Link to post Share on other sites
VR6Pete 1,455 Posted April 10, 2012 Report Share Posted April 10, 2012 Don't forget if it's a daily you will use more fuel! Link to post Share on other sites
michael5556 247 Posted April 10, 2012 Report Share Posted April 10, 2012 I think your talking about the diesel 5th gear to knock 1000 rpm off cruising speed. Link to post Share on other sites
craggsy 91 Posted April 10, 2012 Report Share Posted April 10, 2012 Which TDI tho Don as the 6 speed TDI boxes have 2 FDs Link to post Share on other sites
oldmandon 1 Posted April 10, 2012 Report Share Posted April 10, 2012 Could well be. I know there have been a few post regarding changing final drives for 1 reason or another.. Link to post Share on other sites
VR6Pete 1,455 Posted April 10, 2012 Report Share Posted April 10, 2012 Right im on laptop now so here goes.3.64 FD is from a CDM corrado VR6 box3.68 FD is from a CDA golf gti 16v3.68 FD is from AYL/AYK Corrado G60 and Passat 16v.just for some ideasHonestly thought there was something different with the 16v, it's not just the final drive you need according to stealth racing. Apparently you need the shaft which has the 4 bolts coming from it too. Don't know if they are the same for all boxes that have the 3.68 in them?I'm sticking to what I know. Box is going to stealth in the next few weeks to be built up Link to post Share on other sites
oldmandon 1 Posted April 10, 2012 Report Share Posted April 10, 2012 Right im on laptop now so here goes.3.64 FD is from a CDM corrado VR6 box3.68 FD is from a CDA golf gti 16v3.68 FD is from AYL/AYK Corrado G60 and Passat 16v.just for some ideasHonestly thought there was something different with the 16v' date=' it's not just the final drive you need according to stealth racing. Apparently you need the shaft which has the 4 bolts coming from it too. Don't know if they are the same for all boxes that have the 3.68 in them?I'm sticking to what I know. Box is going to stealth in the next few weeks to be built up [/quote']Are you having the 3.64 FD then Link to post Share on other sites
oldmandon 1 Posted April 10, 2012 Report Share Posted April 10, 2012 Which TDI tho Don as the 6 speed TDI boxes have 2 FDsDon't know? I only know of the 5 speed box. I am thinking of the MK3 diesel though not the later boxes!!! Link to post Share on other sites
VR6Pete 1,455 Posted April 10, 2012 Report Share Posted April 10, 2012 Right im on laptop now so here goes.3.64 FD is from a CDM corrado VR6 box3.68 FD is from a CDA golf gti 16v3.68 FD is from AYL/AYK Corrado G60 and Passat 16v.just for some ideasHonestly thought there was something different with the 16v' date=' it's not just the final drive you need according to stealth racing. Apparently you need the shaft which has the 4 bolts coming from it too. Don't know if they are the same for all boxes that have the 3.68 in them?I'm sticking to what I know. Box is going to stealth in the next few weeks to be built up [/quote']Are you having the 3.64 FD thenNo. 3.68 from a g60 box mate with a rebuilt box, new bearings, seals etc.. Link to post Share on other sites
craggsy 91 Posted April 10, 2012 Report Share Posted April 10, 2012 Could well be Pete, I just have a list of gear ratios and FDs for 1 or 2 VW boxes lol Link to post Share on other sites
oldmandon 1 Posted April 10, 2012 Report Share Posted April 10, 2012 So I'm now guessing that the passat 16v gearbox is also ok to use for the final drive, and seeing as they will probably be more common than the corrado G60, it should also be cheaper??!!!.. Off to ebay I go!! Link to post Share on other sites
craggsy 91 Posted April 10, 2012 Report Share Posted April 10, 2012 I would speak to someone who deffo knows what you need. As Pete says.The FDs may be same ration but may be slightly different, tho if its same code on box it should work Link to post Share on other sites
oldmandon 1 Posted April 10, 2012 Report Share Posted April 10, 2012 No Passat gearboxes with the codes you've mentioned on ebay!!!!!!!!!! That sucks!!! Link to post Share on other sites
vdubtomo 0 Posted April 10, 2012 Author Report Share Posted April 10, 2012 yep VR6Pete its a daily drive, with the fuel prices constantly creeping up what gearbox mods would you recommend whilst iv got it out?Still want it to be driveable but also a bit of fun when the times right! Link to post Share on other sites
vdubtomo 0 Posted April 10, 2012 Author Report Share Posted April 10, 2012 found this....02a VW Transmission CodesATA 3.778 2.118 1.345 0.971 0.795 3.684 Corrado G60 (1989-> 1995)AGC 3.778 2.118 1.345 0.971 0.795 3.944 Passat 16VASD 3.330 1.944 1.308 0.971 0.717 3.944 Passat 16VAYL,AYK 3.778 2.118 1.429 1.029 0.837 3.684 Corrado G60, Passat 16VCCM, CHN 3.300 1.944 1.308 1.034 0.838 3.389 VR6 Passat, Golf/Jetta IIICDM 3.300 1.944 1.308 1.034 0.838 3.647 VR6 CorradoCHA 3.778 2.118 1.360 1.090 .717 3.944 TDI PassatCES 3.778 2.118 1.429 1.029 0.837 3.684 Passat (1992->1994)CTN, CHU 3.778 2.118 1.360 0.971 0.756 3.157 Passat 1.9 ltr, 2.8 ltrCAW 3.778 2.118 1.458 1.034 0.838 3.647 CorradoCNL 3.778 2.118 1.429 1.029 0.837 3.684 2.0L 8V PassatCRU 3.300 1.94 1.308 .971 .0756 4.24 Corrado, Passatso in theory a CDM box out of a corrado VR6 would be ideal if i can find one as i imagine its a straight bolt on???? Link to post Share on other sites
VR6Pete 1,455 Posted April 10, 2012 Report Share Posted April 10, 2012 I'm just about replace my corrado box with a 3.68FD box. Link to post Share on other sites
vdubtomo 0 Posted April 10, 2012 Author Report Share Posted April 10, 2012 how did you find the corrado box?im looking for something that's not too bad on fuel but has a better response than the standard box! Link to post Share on other sites
VR6Pete 1,455 Posted April 11, 2012 Report Share Posted April 11, 2012 pretty sure there is no difference in the corrado box and the golf in the UK...think it was only in counteries where they had to be more restrictive due to emissions they had a tweaked gearbox. Link to post Share on other sites
