kezwaldo 0 Posted April 25, 2012 Report Share Posted April 25, 2012 trying to freshen up handling and ride so have just done both wheel bearings one was really bad and also a ball joint that was advised and its improved loads .........my qeustion is track rod ends seem cheap to buy and easy to replace will this improve the ride and steering ???? not sure if mine are knackered or not but def aint been done in last 5 years ! Link to post Share on other sites
michael5556 247 Posted April 25, 2012 Report Share Posted April 25, 2012 They should be straight forward but usually need a ball joint splitter for it too be easy. But some can be very very stuck on with a lot of swearing. If you can undo the castle but and get the end out it should be easy. Just use lots of penertrating fluid or wd40 etc.. Link to post Share on other sites
kezwaldo 0 Posted April 25, 2012 Author Report Share Posted April 25, 2012 yeah sounds like ball joint i just did that without splitter had some advice to smash the hub with hammer to shock it out and it did after some aggression lol..just hope it improves steering im aiming to renew all front end bearings ,balljoints ,bushes track rods , brakes etc.... Link to post Share on other sites
VR6Pete 1,455 Posted April 25, 2012 Report Share Posted April 25, 2012 You will probably befefit from a 4 wheel alignment from places such as stealth once you have replaced all those said components, if your rear axel bushes and wishbones aint been done yet, id get those done first, also check ARB drop links too. Link to post Share on other sites
kezwaldo 0 Posted April 25, 2012 Author Report Share Posted April 25, 2012 what are ARB links mate ??? Link to post Share on other sites
kezwaldo 0 Posted April 25, 2012 Author Report Share Posted April 25, 2012 and cant a normal tyre place do a 4 wheel alignment Link to post Share on other sites
VR6Pete 1,455 Posted April 25, 2012 Report Share Posted April 25, 2012 http://stealthracing.co.uk/4wheel.php stealth use the Beissbarth VAG1813F alignment stuff, can do camber, toe, alignment etc... usual tyre places wont do that drop links are where your Anti Roll Bar is fixed to your lower arms...will look like Link to post Share on other sites
