cpfcvr6 6 Posted April 25, 2012 Report Share Posted April 25, 2012 my sunroof was working then stopped in the golf mk3, ive since tried 3 motors and no luck. any ideas where to look next? fuse box? if so what fuse or relay is it? Link to post Share on other sites
VR6Pete 1,455 Posted April 25, 2012 Report Share Posted April 25, 2012 Check voltage to the motor with multi meter, if no voltage check switch and fuse. Can't really be much else Link to post Share on other sites
cpfcvr6 6 Posted April 25, 2012 Author Report Share Posted April 25, 2012 what number fuse it is bud?? also switch you mean the switch you use to open and close it? Link to post Share on other sites
rsweeney 40 Posted April 29, 2012 Report Share Posted April 29, 2012 its fuse 16 i think .with motor attached use an alan key to manually wind the sunroof back and forwards , just to check it runs smoothly and the mechanisms arent jammed or broken. I had a perfectly good sunroof motor but didnt work as mechanisms where jammed Link to post Share on other sites
cpfcvr6 6 Posted May 9, 2012 Author Report Share Posted May 9, 2012 sorted guys many thanks! Link to post Share on other sites
VeeRsix 0 Posted May 31, 2012 Report Share Posted May 31, 2012 it would help others searching for answer more if you actually posted what exactly "sorted" it m8Stephen Link to post Share on other sites
