cpfcvr6 6 Posted May 9, 2012 Report Share Posted May 9, 2012 hi peeps and lassesmy golf vr6 has a hell of a lot of play in the throttle pedal, its almost halfway to the floor it sits now, so you can lift it with ease to the same height as the brake and clutch pedal, push it and it will fall back down to halfway point. :-) Link to post Share on other sites
cpfcvr6 6 Posted May 11, 2012 Author Report Share Posted May 11, 2012 anyone guys? this is how it sits now, it used to sit level with the clutch and brake pedal!you can pull it level with the clutch and brake but it just has a lot of play??? now it sits half way down it doesnt afect the idle though?? Link to post Share on other sites
cpfcvr6 6 Posted May 12, 2012 Author Report Share Posted May 12, 2012 i take it this isnt a common problem then? Link to post Share on other sites
MJ Vr6 79 Posted May 12, 2012 Report Share Posted May 12, 2012 i take it this isnt a common problem then?Check throttle cable mate!! Link to post Share on other sites
cpfcvr6 6 Posted May 12, 2012 Author Report Share Posted May 12, 2012 i take it this isnt a common problem then?Check throttle cable mate!!its brand new genuine VW!!was working well for a couple of months! Link to post Share on other sites
VIW28 29 Posted May 13, 2012 Report Share Posted May 13, 2012 I think there's a spring on the bar that comes up either back of the dash where the cable clips in through the bulkhead, is that attached? Link to post Share on other sites
cpfcvr6 6 Posted May 13, 2012 Author Report Share Posted May 13, 2012 I think there's a spring on the bar that comes up either back of the dash where the cable clips in through the bulkhead' date=' is that attached?[/quote']ok hope its not a dash out job? Link to post Share on other sites
VIW28 29 Posted May 13, 2012 Report Share Posted May 13, 2012 Shouldn't be, hole in bulkhead is big enough to get something through to hook the spring. Could be talking through my arse here though but seem to remember one on mine! Link to post Share on other sites
robadobadob 0 Posted May 14, 2012 Report Share Posted May 14, 2012 Had something like this on our Mk1 Golf turbo, the cable had pulled through the bulkhead so only half throttle was achieved.Worth a look. Link to post Share on other sites
CALICO 130 Posted May 14, 2012 Report Share Posted May 14, 2012 It's normally the clutch cable on the mk1 that pulls through the bulkhead and to remedy that you could buy a plate for the cable to go through I'm sure it's a different arrangement on the mk3 though. Link to post Share on other sites
cpfcvr6 6 Posted May 15, 2012 Author Report Share Posted May 15, 2012 ok thanks guys, even though it sits halfway down it still retracts ok so i dont think a spring has come off as such?suprised nowone else has had this problem? Link to post Share on other sites
CALICO 130 Posted May 15, 2012 Report Share Posted May 15, 2012 Have you checked to make sure the circlip is in place where it goes through the bracket before it gets to the throttle body? Link to post Share on other sites
yakuza racer 16 Posted May 15, 2012 Report Share Posted May 15, 2012 strange issue indeed, but like calico said, make sure the cable by the engine bay is secured and everything there is in place correctly before climbing into your dash. Link to post Share on other sites
cpfcvr6 6 Posted May 15, 2012 Author Report Share Posted May 15, 2012 strange issue indeed' date=' but like calico said, make sure the cable by the engine bay is secured and everything there is in place correctly before climbing into your dash.[/quote']ive taken the engine covers off today and everything looks fine regarding throttle cable. Link to post Share on other sites
paceo 22 Posted May 21, 2012 Report Share Posted May 21, 2012 ive got the same problem? lol Link to post Share on other sites
CALICO 130 Posted May 21, 2012 Report Share Posted May 21, 2012 Im only in Crawley maybe i could pop up with mine so as you can compare im working nights until Thursday then back on days Saturday Sunday so could do Thursday or friday day or evening or Saturday Sunday night. Link to post Share on other sites
