Deegolfvr6 0 Posted May 15, 2012 Report Share Posted May 15, 2012 Hi guys I had an oil leak through my oil pressure switch, I changed the switch and oil Leak has stopped but my oil light on my dash is now flashing like mad. Any ideas on this would be much appreciated.Thanks Link to post Share on other sites
yakuza racer 16 Posted May 15, 2012 Report Share Posted May 15, 2012 you must have replaced it with the incorrect switch, there is 3 switches on the oil filter housing, which one was it? the green wire is the oil temp switch (smaller than the other two) Link to post Share on other sites
Deegolfvr6 0 Posted May 15, 2012 Author Report Share Posted May 15, 2012 From what I can tell from my research there's the temp sensor at the top back of the casing and 2 pressure switches at the front a 1.8 bar and 1.3Bar it's the 1.3 bar switch that has gone and I replaced it with a 1.3 bar switch from euro car parts Link to post Share on other sites
yakuza racer 16 Posted May 15, 2012 Report Share Posted May 15, 2012 yeah that is correct.perhaps you got the incorrect wires plugged in?should fix up once the new switch is installed, either that or the switch that was sent could be a factory fault, things like that do happen on occasion. Link to post Share on other sites
Deegolfvr6 0 Posted May 15, 2012 Author Report Share Posted May 15, 2012 Yeah think I'm gonna have 2 try a new switch, only had that switch disconnected so it's the correct wire plugged in. Thanks for your help I'll let you know how I get on Link to post Share on other sites
yakuza racer 16 Posted May 15, 2012 Report Share Posted May 15, 2012 no issues mate, hope you get sorted. Link to post Share on other sites
Deegolfvr6 0 Posted May 15, 2012 Author Report Share Posted May 15, 2012 Had a play with the switch when I unplug it my oil light goes off then when I plug it back in the light starts flashing again. I'm guessing that it mite be the wrong switch I've been given? Link to post Share on other sites
Lukey. 381 Posted May 16, 2012 Report Share Posted May 16, 2012 That doesn't sound right, IIRC it should flash if not plugged in too Link to post Share on other sites
yakuza racer 16 Posted May 16, 2012 Report Share Posted May 16, 2012 x2 on what lukey said mate. Link to post Share on other sites
Deegolfvr6 0 Posted May 17, 2012 Author Report Share Posted May 17, 2012 Yeah I thought that 2 its a bit of a puzzle just tryin 2 find time to sort it out . do u guys think trying a new switch will help or maybe its a fault with the VRs wiring? Link to post Share on other sites
Lukey. 381 Posted May 17, 2012 Report Share Posted May 17, 2012 Did it work properly before? If it did I'd swap for another sensor Link to post Share on other sites
Deegolfvr6 0 Posted May 17, 2012 Author Report Share Posted May 17, 2012 Yeah it was grand till the oil leak through the switch. Shall I go 4 a gen vwpart or is euro car parts ok never went wrong with them in the past? Link to post Share on other sites
Lukey. 381 Posted May 17, 2012 Report Share Posted May 17, 2012 for the price of a sender get a proper one bud Link to post Share on other sites
