paceo 22 Posted May 16, 2012 Report Share Posted May 16, 2012 recieved my 312mm brake conversion vr6 vr6mike on here.. just wondering are these the hoses for the early golf VR6? mines a J -registration 1992 obd1.also these were cut on the brake pads, i know its to tell you the pads are getting low etc.... Link to post Share on other sites
Lukey. 381 Posted May 16, 2012 Report Share Posted May 16, 2012 The car end of the hoses are the same for early and late, does your VR even have brake pad warning? My 97 doesn't I just cut the wires off my pads Link to post Share on other sites
paceo 22 Posted May 17, 2012 Author Report Share Posted May 17, 2012 The car end of the hoses are the same for early and late' date=' does your VR even have brake pad warning? My 97 doesn't I just cut the wires off my pads[/quote']oh right i thought the early obd1 had to have the brake hoses changes to suite the 312mm calipers?i have no brake warning wires on mine at the moment! Link to post Share on other sites
craggsy 91 Posted May 17, 2012 Report Share Posted May 17, 2012 It's the calipers end that's different. Obd1 screw into the calipers whereas the ones you have there don't, we'll they do just a different way ie banjo Link to post Share on other sites
paceo 22 Posted May 17, 2012 Author Report Share Posted May 17, 2012 It's the calipers end that's different. Obd1 screw into the calipers whereas the ones you have there don't' date=' we'll they do just a different way ie banjo[/quote']so do i need to do anything craggsy? or just bolt them straight on my 1992 vr6? sorry im kind of on a learning curve still! Link to post Share on other sites
craggsy 91 Posted May 17, 2012 Report Share Posted May 17, 2012 Should just bolt up the youe existing hard lines Link to post Share on other sites
