The black knight, Corrado VR6
This is my Corrado. I bought it after a break from the 'VW scene' and immediately loved it. Its a 1995 Corrado VR6 in metallic black.
Spec is as follows:
Full respray in 2010 in original metallic black
KW V1 coilovers
Refurbished BBS (RJ's?) with Proxes t1-s
Lupo wiper conversion
Rear wiper deleted
Full cream leather storm interior with working electric recaros
Black faux saude headlining with black switches
Audioscape door pods
Custom built sub box and boot false floor
2.9 ABV engine 117,000 miles
Polished inlet manifold and tensioner
Carbonio air intake
Samco hoses
Magnacore HT leads
Eibach strut brace
Milltek exhaust system
Couple of pics with my mk2 16v GTI daily
I recently broke another Rado for spares, from which I kept the suspension and running gear to restore and fit to this car.
Starting with the wishbones. Sand blasted and gold zinc plated, then powdercoated for extra durability
And front uprights
I started stripping the rear floorpan and suspension and restoring parts.
Fuel tank and heat shields removed
Rear beam sand blasted and powdercoated in original black
And the front subframe.
Rear callipers rebuilt
All new rear fixings gold zinc plated to match the original finish.
Brake backing plates restored
Centre exhaust hanger
Front anti roll bar
Rear hubs
Fuel tank straps
I inspected the floorpan, removed the original sealant in any areas susceptible to corrosion and removed any rust that I found with a big pneumatic wire brush (6) Then primed and painted the bare areas before schutzing the whole floorpan.
Rear beam brackets removed, sand blasted and powder coated and refitted with new bolts.
Rear shocks removed and cleaned
Heat shields blasted and painted with a zinc based paint
I drained the fuel tank and removed the fuel pump
I cleaned the inside of the tank and removed any debris
Fuel pump refitted
Exterior of the tank cleaned up
Thats all for now, the next jobs are to schutz the rear arches and refit the rear shocks. Fit new bushes to the rear beam and fit the beam to the car and build up the rear hubs.
Comments and criticisms welcome.
Cheers. Bryn.
Thanks for the kind comments guys :-). The car will most likely be kept for summer use only, but I wouldn't mind entering a few concourse competitions, although there will be quite a few unoriginal modifications and improvements to various parts, so it probably wouldn't do brilliantly haha. I just wanted to build a really nice, honest Corrado that drives like new.
Thanks. Bryn.
  • 3 weeks later...
Small update.
I have had another load of fastenings plated, these are all original, just cleaned, blasted and replated.
I have removed the front to rear brake lines completely, both fuel lines and the exhaust from the manifold backwards (found a broken wire to the lambda which I will need to repair at a later date.)
The rear floor pan section is now fully sealed and I am happy with the finish.
Freshly plated handbrake cable guides.
Offside floor pan stripped, rust repaired and re-sealed
Arches sealed and shocks back on
The rear beam has been removed again so I can fit the new bushes and then it will be refitted and I can build it back up.
Cheers. Bryn
Update time.
New fuel lines made up and fitted, there's a few small bends in the pic which I have now straightened out.
Fuel tank back in, just waiting on the proper bolts to come back from the platers
And the beam is finally back in! I fitted new genuine rubber bushes which turned out to be a bit of a headache, but it's all worth it to see it back in now :)
Also bolted on the rear spindles, I've just got to modify the new spacer ring that sits behind the disc and fit the bearings and the car could go back on its wheels!
Next jobs:
Modify the rear disc spacer rings
Make the solid brake pipes for the rear callipers and mount them with the abs wiring on the rear beam.
Fit the heat shields for good once the new clips come back from plating
Fit the rear bearings to the new discs and fit to the car
Fit the rear callipers and adjust the handbrake.
Just noticed a shot in the old pictures I can compare before and after :-)
Before
After
Makes it all worth while seeing that haha.
Thanks.
Bryn.
Bloody el. Lol absolutely brill making me really do this to the mk3. Have you got a bentley manual for all the torque setting on the bolts? Are they braided fuel hoses? If so I like the look of those too. :)
I've had a really good day today cracking on with the Corrado. Firstly I fitted the new discs and bearings with new genuine pickup rings plated silver.
No pads in yet, because I'm not sure what I'm going to go for and it's going to be a while before the car is on the road again so they would only be sitting around.
Hand brake cables all clipped in and Brake carriers and dampers bolted up and tight.
Brake pipes finished
Quick shots of the underside before I put the car back on its wheels
It's back on the ground! It's only taken 4 months :-s
Then this happened..
I have still got a couple of last jobs to do underneath but I was too excited at the prospect of getting it rolling again I couldn't wait another minute haha. I'm sitting here now trying to suss out recaro seat wiring.
Cheers guys.
Bryn.
  • 3 years later...
