Hi there,
After being stung on EBay by a set of clocks that were both half faulty and totally incorrect mileage as stated :@
I am now on the lookout again for a set of clocks that reflects the mileage covered since the engine under-went a full rebuild but are the ports at the back of OBD1 and OBD2 clocks the same?
Im running OBD1 in a mk2 Golf so any advice is needed before i end up getting another wrong set of clocks!
Ok but its a case now where i need a new clock/instrument panel itself - its a long story! :-(
Just need to know if the clocks from mk3 vr6's are all the same connector at the back, whether it be OBD1 or 2?
Cheers
