madvr6 0 Posted March 27, 2005 Report Share Posted March 27, 2005 Does anybody have a part number for this? Apparentl only used on early VR's AAA engines i think because they fail quite often. Well im sure mine is knakerd and makes the car a pig to drive so need a part no. to tell VW.Appreciate any helpCheers Link to post Share on other sites
madvr6 0 Posted April 25, 2005 Author Report Share Posted April 25, 2005 Ok managed to get hold of this from VW, i'll put the part number up later for future reference incase anybody needs it.Just trying to find out, if this needs any "setting up" as such or is it just a case of, old one off.... new one on?Thanks Link to post Share on other sites
Zonda_ 0 Posted April 26, 2005 Report Share Posted April 26, 2005 Out of interest what were the symtoms. Mine is driving like crap at the mo too. Its a 94. I'm 90% sure its the cat thats packed up but the potentiometer has been mentioned too. Link to post Share on other sites
FishWick 21 Posted April 26, 2005 Report Share Posted April 26, 2005 You need to reset the ECU after you change the Throttle Position sensor.There isn't much you can do by way of setting up, other than ensuring the throttle angle at rest is less than 14 degrees (VAG-COM required).Symptoms of a knackered TPS included erratic idling, flat spots and jerky part throttle cruising. Link to post Share on other sites
madvr6 0 Posted April 26, 2005 Author Report Share Posted April 26, 2005 Thanks for that, thoes are the axact symptoms that i have! Link to post Share on other sites
stu h 0 Posted April 26, 2005 Report Share Posted April 26, 2005 if this is knackered will it show up on VAG COM??mine is sometimes seems ever-so-slightly (and i mean barely niticable) jerky at constant speed and a slightly erratic idle. no flat spots that i've noticed and the rr graph curve was about as smooth as Link to post Share on other sites
alanf 0 Posted April 27, 2005 Report Share Posted April 27, 2005 Any chance of the part number? as the sympton described are exactly the same as the ones I have ~ very jerky on off throttle, hanging throttle on over run 1600/2000 rpm! erratic idle and variable flat spots ~ had the codes read and they pointed to the throttle position sensor :? but I was told by both VW and Ford that it wasnt available as a seperate item but only with the throttle body &| which isnt cheap! thanks in advance Link to post Share on other sites
malcolm 0 Posted April 27, 2005 Report Share Posted April 27, 2005 Believe there are 3 types of theseVariante Nr. 1 VW-Nummer : 037 907 385 QVariante Nr. 2VW-Nummer : 021 907 385Variante Nr. 3VW-Nummer : 021 907 385 B I have pictures of them if you send me an e-mail address Link to post Share on other sites
