Throttle Valve Potentiometer????
Does anybody have a part number for this? Apparentl only used on early VR's AAA engines i think because they fail quite often. Well im sure mine is knakerd and makes the car a pig to drive so need a part no. to tell VW.
Appreciate any help
Cheers
  • 5 weeks later...
Ok managed to get hold of this from VW, i'll put the part number up later for future reference incase anybody needs it.
Just trying to find out, if this needs any "setting up" as such or is it just a case of, old one off.... new one on?
Thanks
You need to reset the ECU after you change the Throttle Position sensor.
There isn't much you can do by way of setting up, other than ensuring the throttle angle at rest is less than 14 degrees (VAG-COM required).
Symptoms of a knackered TPS included erratic idling, flat spots and jerky part throttle cruising.
if this is knackered will it show up on VAG COM??
mine is sometimes seems ever-so-slightly (and i mean barely niticable) jerky at constant speed and a slightly erratic idle. no flat spots that i've noticed and the rr graph curve was about as smooth as
Any chance of the part number? as the sympton described are exactly the same as the ones I have ~:( very jerky on off throttle, hanging throttle on over run 1600/2000 rpm! erratic idle and variable flat spots ~:( had the codes read and they pointed to the throttle position sensor :? but I was told by both VW and Ford that it wasnt available as a seperate item but only with the throttle body &| which isnt cheap! :o
thanks in advance
