Vr6 in mk2.......engine running problem after block swap. Please help! :-(
Ok i have the Vr in my mk2 and after a big slap of misfortune the bottom end went. I have replaced the whole block and bolted on all my obd2 parts.
It runs perfectly fine when cold, and will do for around 3-5 minutes then like a switch it will start running badly, no power like the timings out or a cylinder down.
Changed all plugs, changed thermostat, Unpluged one ht lead at a time and every one takes a cylinder out with a audible difference so definately running on all 6!
Haven't a clue what it is so any help much appreciated!
Exactly the same when i unplug the maf sensor. not sure about fuel pressure but like said its like a switch. I can jump in it from completely cold and its fine for 3-4 minutes and drive as quick as i like. Then like a switch it starts running like a bag of pooooo
