allsmiles 0 Posted June 20, 2012 Report Share Posted June 20, 2012 hi folks just a quick question really, my mk3 golf vr6 is losing coolant, not a large amount but about half a litre a week, also ive noticed there seems to be pressure in the coolant tank(seems to be bubbling up) any ideas folkscheers Link to post Share on other sites
VR6Pete 1,455 Posted June 20, 2012 Report Share Posted June 20, 2012 any visible signs of leakage on the floor? put some cardboard under neath the engine to try and identify where it could be coming from...check to make sure your thermostat is functioning correctly and that there are no leakes on the thermostat housing etc... Also check the cap on the coolant bottle, sometimes the seal goes and it perishes, thus will bubble out etc... but also a stuck thermostat can cause that to happen when upto temp (are your fans working etc? What are your water temps like?). Link to post Share on other sites
allsmiles 0 Posted June 20, 2012 Author Report Share Posted June 20, 2012 there doesnt seem to be no obvious leakage on the floor but im going to put some cardboard underneath and run it up to temperature, water temperature seems fine and the temperature only seems to go halfway up the gauge and doesnt go any further(never heard the fans ever work) but i will get the thermostat and coolant cap changed anyway as i dont think they will be that expensive so i can rule those outmany thanx and i will report backjust to add, oil is fine, no mayo Link to post Share on other sites
Lukey. 381 Posted June 20, 2012 Report Share Posted June 20, 2012 is there like a pink talc residue anywhere on the engine, hoses or expansion tank? this would indicate a leak or bad seal Link to post Share on other sites
allsmiles 0 Posted June 20, 2012 Author Report Share Posted June 20, 2012 is there like a pink talc residue anywhere on the engine' date=' hoses or expansion tank? this would indicate a leak or bad seal[/quote']no pink talc can be seen Link to post Share on other sites
Dirtysanchez 0 Posted June 20, 2012 Report Share Posted June 20, 2012 Crack pipe cracked maybe? Link to post Share on other sites
sedge 7 Posted June 20, 2012 Report Share Posted June 20, 2012 Have a feel around inside the car, behind the centre console. If it feels a little damp in there could be the heater matrix leaking?Just had to change that on my mk2 and its the same matrix as mk3's so maybe prone to the same problem? Link to post Share on other sites
Lukey. 381 Posted June 20, 2012 Report Share Posted June 20, 2012 Another heater matrix telltale is that the screen will steam up if you put the blower full hot on the screen Link to post Share on other sites
allsmiles 0 Posted June 22, 2012 Author Report Share Posted June 22, 2012 thanx for the help folks, will find the time this weekend to see what the crack is Link to post Share on other sites
