cpfcvr6 6 Posted June 27, 2012 Report Share Posted June 27, 2012 alright peeps. my 6 branch racelands is blowing from the 3 bolt connector around the seal, can you get these new or would some high temperature silicone do the job?also ive got a split CV runner gaitor, how do you get the CV joint off?? i cant see no circlip holding it in??? Link to post Share on other sites
cabrioman 6 Posted June 27, 2012 Report Share Posted June 27, 2012 is it blowing between the two flat faces ???? if so you can get a gasket that goes in there or yeah high temp sealant will do the trickas for the cv joint it should just bang off the shaft Link to post Share on other sites
craggsy 91 Posted June 27, 2012 Report Share Posted June 27, 2012 VW/TPS sell the gasket as its a standard part if it's between cat and racekand Link to post Share on other sites
cpfcvr6 6 Posted June 27, 2012 Author Report Share Posted June 27, 2012 is it blowing between the two flat faces ???? if so you can get a gasket that goes in there or yeah high temp sealant will do the trickas for the cv joint it should just bang off the shaft not the two flat faces, thats a new gasket, its blowing from the 6 branch, you know the 3 way adaptor that goes on it theres like a metal wire seal on that. put some high temp sealant on it, stopped most of the blowing but still blows a bit! Link to post Share on other sites
cpfcvr6 6 Posted June 29, 2012 Author Report Share Posted June 29, 2012 is it just a hammer you use to tap the CV joint off? dont want to damage it!also will it just be hand pressure to put it back on the shaft? Link to post Share on other sites
