rsweeney 40 Posted June 27, 2012 Report Share Posted June 27, 2012 When reversing i get a clear clunk when pressing the brake pedal. it comes from front passengers side, is it the driveshaft needing replacement? i checked all bolts and they are tightif so best to go second hand or new ? cheers Link to post Share on other sites
filtee 0 Posted June 28, 2012 Report Share Posted June 28, 2012 Could be a ball joint or bush. Link to post Share on other sites
robadobadob 0 Posted June 28, 2012 Report Share Posted June 28, 2012 Could just be the pads shifting slightly in the caliper. Mine does that. Link to post Share on other sites
Vw_owner 1 Posted July 3, 2012 Report Share Posted July 3, 2012 jack it up and put a block on the brake pedal so the brakes are on {or have a m8 put the brake on} and grab the wheel and try to turn it clockwise and then anti clockwise to see if you can get any play out of the caliper, if you know what i mean? could be the guide pins on the caliper carrier Link to post Share on other sites
rsweeney 40 Posted July 3, 2012 Author Report Share Posted July 3, 2012 sorry ment to update this , when looking for play in bushes i realised one of the retaining bolts for the caliper carrier had come loose , tightened it up and no more noise. Link to post Share on other sites
