rsweeney 40 Posted July 2, 2012 Report Share Posted July 2, 2012 everytime i drive over bumps or rough sections of road i get a clunking noise from passengers front side .Fitted is PI 30mm lowering springs. it only does this one the passengers front side .any ideas? Link to post Share on other sites
CALICO 130 Posted July 2, 2012 Report Share Posted July 2, 2012 If the shock absorber is fine then the wishbone bushes could be shot Link to post Share on other sites
Lukey. 381 Posted July 2, 2012 Report Share Posted July 2, 2012 Or ball joint, or drop link Link to post Share on other sites
rsweeney 40 Posted July 2, 2012 Author Report Share Posted July 2, 2012 bloody hell just removed wheel and one of the caliper bolts needing nipping up and now the noise is gone. i cleaned bolt threads, used locite and torqued up to be sure, Link to post Share on other sites
Lukey. 381 Posted July 2, 2012 Report Share Posted July 2, 2012 Dunno if loctite is the best idea though, what if it welds itself in when you need to change pads? Link to post Share on other sites
rsweeney 40 Posted July 3, 2012 Author Report Share Posted July 3, 2012 it was on the bolts holding the caliper carrier to the hub, i could always remove them again to get rid of the loctite and torque them up but i didnt think you had to remove them to change pads ? Link to post Share on other sites
Lukey. 381 Posted July 3, 2012 Report Share Posted July 3, 2012 Oh right the carrier bolts, no you don't need to remove them to change pads but you do to change discs Link to post Share on other sites
