gavinvr6 0 Posted July 8, 2012 Report Share Posted July 8, 2012 Couple of questions. Would like to know if they would come up/show up in an mot and if they would be a fail or advisory. Vehical is a 3.5t ldv vancoolant tank-visible obvious leakKnocking on suspension, bottom ball joints replaced, still doing it just slightly less.Knocking noise under initial load (gear stick jerking at same time)Vibration on brakes when slowing from motorway speed, front brakes replaced. Link to post Share on other sites
cabrioman 6 Posted July 8, 2012 Report Share Posted July 8, 2012 the coolant leak could be put down as an advisory ...the brake judder could cause it to fail ...knocking on the suspension all depends what is causing it if a component is excessively worn then it could fail ...but it is all down to the tester ...... Link to post Share on other sites
Woodyman84 3 Posted July 8, 2012 Report Share Posted July 8, 2012 i would say most MOT tester will fail knocking bottom ball joints, its a common issue on most vehicles and they tend to test them quite thoroughlyI always tend to get friendly with my local garage so i can take the car away and fix the faults myselfas said above tho it really is down to the individual tester Link to post Share on other sites
gavinvr6 0 Posted July 8, 2012 Author Report Share Posted July 8, 2012 Its not dull thud from worn rubber its to harsh for that. Apparently its just past an mot. But I'm not entirely convinced its road worthy. Link to post Share on other sites
Woodyman84 3 Posted July 8, 2012 Report Share Posted July 8, 2012 well when i had a tiny knock on my audi a4 from bottom ball joint it was a fail an thats from an mot garage ive been using for 10 years and trust entirely. if its a harsh knock id be worried how it had passed Link to post Share on other sites
gavinvr6 0 Posted July 8, 2012 Author Report Share Posted July 8, 2012 My main concern is I was told bottom ball joint were gone, mechanics words were f***ing hanging out, speed bump equals seperation. Also beleived other suspension components needed attention as did engine mounts. But the mechanics who did the work just replaced bottom ball joints and left the rest.This is a company vehical so the first fitter would have no reason to lie about bits failing, where as the others who done the works are known to be lazy w***ers. I been moaning the header tank is leaking for 3 months and they have seen it themselves, Not even convinced it actually went for an mot and they were just saying it to get me off their backs moaning about it. Banging about, brakes vibrating and knocking under load and braking at low speed. Link to post Share on other sites
Lukey. 381 Posted July 9, 2012 Report Share Posted July 9, 2012 The knocking with gearstick movent I'd say is excessive engine mount play Link to post Share on other sites
CALICO 130 Posted July 9, 2012 Report Share Posted July 9, 2012 You could bring up your concerns with Vosa if you are suspicious. Link to post Share on other sites
gavinvr6 0 Posted July 9, 2012 Author Report Share Posted July 9, 2012 The yard/depot manager showed me the mot receipt u get nowadays and it has no advisories in the box on the right. This is from a reputable business who we have been using for years. Link to post Share on other sites
Lukey. 381 Posted July 9, 2012 Report Share Posted July 9, 2012 Doesn't mean they didn't do something dodgy, I've seen several cars for sale with recent (backhanded in my view) mots that had damage that had to have been there too long for it to have happened afterwards. Link to post Share on other sites
