rsweeney 40 Posted August 24, 2012 Report Share Posted August 24, 2012 for a few years now when i go to start the vr from cold it takes a good 3 or 4 seconds before it fires into life .however when hot it starts instantly as soon as you turn the keyanyone able to help here? i was thinking possible fuel pressure problem but not sure . ( its had new fuel filter recently )its an automatic golf vr6 94 Link to post Share on other sites
joeshaw123 0 Posted August 24, 2012 Report Share Posted August 24, 2012 Could very well be an initial fuel pressure problem. There is a check valve on the fuel pump that can fail and allow fuel to bleed back down the lines into the tank. It shouldn't be a problem really, it just puts a bit more strain on your starter motor. If you replace the fuel pump then it'll start like it should do.I have a fuel pump in my garage if you can't source one. Now someone help me with my problem! hahahope this helps Link to post Share on other sites
rsweeney 40 Posted August 24, 2012 Author Report Share Posted August 24, 2012 ah thanks mate , is this valve something that you can replace or buy from vw ? and is the valve inside the tank or can i get to it with just removing the access plate for fuel pump ? thanks Link to post Share on other sites
spadam 7 Posted August 24, 2012 Report Share Posted August 24, 2012 Sounds like coolant temp sensor which are very common problem.Think its the blue or green sensor on the thermostat housing.They sart to read the wrong temperture and dont allow enough fuel when cold. Link to post Share on other sites
rsweeney 40 Posted August 24, 2012 Author Report Share Posted August 24, 2012 Sounds like coolant temp sensor which are very common problem.Think its the blue or green sensor on the thermostat housing.They sart to read the wrong temperture and dont allow enough fuel when cold.i have read about this , the coolant temperature guage on dash seems to read ok but could it still be incorrect ? if so i may start with this sensor, do i have to buy if from vw dealer or can i buy it online from somewhere like vwspares.co.uk? Link to post Share on other sites
filtee 0 Posted August 24, 2012 Report Share Posted August 24, 2012 Sorry to hijack the thread but i have a similar issue but mine is hard to start when warm. Ive heard about the fuel pressure thing also. Is this correct that replacing the fuel pump will cure it? Link to post Share on other sites
craggsy 91 Posted August 24, 2012 Report Share Posted August 24, 2012 The blue temp sensor only sends info to the ecu not the dash Link to post Share on other sites
The Duke 27 Posted August 24, 2012 Report Share Posted August 24, 2012 I had the same cold start problem on my first VR once I replaced the blue temp sensor it was fine. I got it from euro car parts for a tenner I think. Link to post Share on other sites
rsweeney 40 Posted August 24, 2012 Author Report Share Posted August 24, 2012 cheers for the replys i will do blue temp sensor first and see what this does,will update with the result. Link to post Share on other sites
spadam 7 Posted August 24, 2012 Report Share Posted August 24, 2012 As craig says blue sensor not related to the dash. Costs around £7 from vw and cured my problem. Its a well known fault on all the vag group. Link to post Share on other sites
rsweeney 40 Posted August 29, 2012 Author Report Share Posted August 29, 2012 just got a price from vw guernsey , £16.75!! going to bite the bullet and buy it but why so expensive over here and not the uk ? Link to post Share on other sites
UnitedMotorsport 55 Posted August 29, 2012 Report Share Posted August 29, 2012 Because the other guys are talking about non VW prices. Link to post Share on other sites
spadam 7 Posted August 29, 2012 Report Share Posted August 29, 2012 Sorry should have said i brought my sensor about 4 years ago so prices may have risen. Link to post Share on other sites
rsweeney 40 Posted August 29, 2012 Author Report Share Posted August 29, 2012 ah right its no prob, i guess genuine from vw is best though ? Link to post Share on other sites
rsweeney 40 Posted September 3, 2012 Author Report Share Posted September 3, 2012 right, fitted new blue temp sensor along with flushing the cooling system and refilling with new coolant ( blue type ) and water.runs alot smoother and slightly quicker to start but will need to try again in the morning to be certain.however the coolant temperature creeped up to just under 100 degrees ( needle going past verticle ) when idling after a good run.anything to worry about ? Link to post Share on other sites
spadam 7 Posted September 3, 2012 Report Share Posted September 3, 2012 Possibly an airlock in the system. Also i thought only g12 coolant was supposed to be used which is pink. Link to post Share on other sites
rsweeney 40 Posted September 3, 2012 Author Report Share Posted September 3, 2012 tomorrow i will run it up to temp with coolant cap removed to try and remove air from system. I used blue antifreeze as its all i had , it doesnt have any cooling properties i thought though does it, only stops corrosion? Link to post Share on other sites
spadam 7 Posted September 3, 2012 Report Share Posted September 3, 2012 Yea sorry didnt mean it was contributing to the overheating just thats its not recomended to use it. Link to post Share on other sites
The Duke 27 Posted September 3, 2012 Report Share Posted September 3, 2012 I used to live in Guernsey n got all my parts for my old Volkswagens from a garage around the back of Blind O'Rileys but can't remember the company's name for the life of me, they we're just off Collins road before that but did a lot of work on my old mk2 golf n were always good for parts too. Link to post Share on other sites
Lukey. 381 Posted September 3, 2012 Report Share Posted September 3, 2012 You have to be careful when mixing if you changed to/will ever want to go on to G12 from the blue stuff, they should not be mixed as they react with each other Link to post Share on other sites
The Duke 27 Posted September 4, 2012 Report Share Posted September 4, 2012 Euromarque is the name of the garage they should be able to sort you parts at a good price. It's been a long time since I've felt with them. Link to post Share on other sites
rsweeney 40 Posted September 4, 2012 Author Report Share Posted September 4, 2012 right i understand now will have to buy the vw G12 coolant and completely flush the system of the blue stuff before putting G12 in.what mix of coolant to water is it ?yeh i have used euromarque before and they are decent just slightly expensive , i do all work on the vr myself though as i enjoy it and keeps costs down. Link to post Share on other sites
Lukey. 381 Posted September 4, 2012 Report Share Posted September 4, 2012 3x 1.5l bottles is sufficient then top the rest up with (preferably de-ionised) water Link to post Share on other sites
rsweeney 40 Posted September 5, 2012 Author Report Share Posted September 5, 2012 today i sorted out the coolant by flushing through the system and changing it for longlife coolant ( 5year stuff ) . The mix is 4litres of coolant and rest distilled water.Whilst running is silky smooth cold starting still takes a noticeable amount of time.what should i try next? Link to post Share on other sites
