Hi everyone' date=' basically I've fitted a turbo kit to my vr6, and I don't know where to remap it, I've spoke to Matt at United Motorsport and said he can't remap it because mine is a obd1 with a coil pack, so I need your advice
I said we no longer support OBD1, not that I 'cant' do it.
OBD1 barely has enough control to run a good NA tune, this is why we no longer support OBD1.
By searchin i found that you need:
engine loom from fuse board out & the engine main loom (injector loom)
maf
lamdba
throttle body
mani
fan control unit
engine cooling fan
ECU with matchin key and immb ring
some re-wiring for the ABS
Doesn't sound a 2 minute job tbh
maf
lamdba
throttle body
mani
fan control unit
engine cooling fan
Tony managed to do it in 2-3 days all together.
You will need:
maf
lamdba
throttle body
mani
ECU
Imobiliser / ring / key chip (However its easier if you get the imob delete!)
The ABS loom on my corrado is seperate from the engine / injector loom and and just worked.... I re-used my old OBD1 fan control unit and existing fans. it was all plug and play, only other thing to buy is a shed loads of loom tape which I got from Audi for under a fiver a role!
it really is a DIY job with the useful information we we had available.... ive uploaded some info below that we followed... the only minor issues we had was with the aux pump / fan stages which was simply another wire we'd forgotton to connect a red wire up to the multi-plug... it idles and pulls 1000x better than with the OBD1 stuff and looks factory fitted with a little effort!
Pretty sure that a couple of people on here have converted their Golf's without much hassle either... :)
Pete
