cj_wig 0 Posted September 22, 2012 Report Share Posted September 22, 2012 Seeing as i'm new here i thought i'd better get some pictures up. I got this on Wednesday off a lad i know. Here is the spec from the ad:-1992 Vw Golf Mk3 2.8 Vr6 OBD1 Engine, Gearbox, Ecu, Cable Gear links, Radiator & Engine mounts.Seat Toledo Tdi front hubs, Cable clutch conversion.Seat Ibiza Gti Cupra sport 2.0 16v (T Reg) Brakes Front discs are Drilled and Grooved 280mm with Greenstuff pads, standard rear discs and pads, Driveshafts, Front Anti-Roll bar & links.Seat Cordoba throttle pedal and cable.Bored out throttle body, and many many new or uprated bits like, new rotor arm, dissy cap, ht leads, ignition amplifier, coil, serpentine belt, tensioner, water pump, carbon kevlar race clutch and heavy duty balanced pressure plate, clutch cable... the list goes on and on.....2.3 v5 dzl code 5 speed gearbox for shorter ratio's and a much tighter diff.The exhaust system: Standard 2.8 Vr6 manifold and downpipe, De-cat custom made mid-section 2¼" straight through to a Remus twin exit Stainless Back box.Climate control.Good Bits:178 bhp (170 standard) with dyno print out from Get Dyno'd.Short ratio (DZL) (2.3 V5) gearbox 140mph final drive makes for much faster accelaration.17" drifz wheels unique carbon look (all tyres legal with life left)Coilovers all roundRear interior removed (but not carpets or door cards so looks pretty tidy) and black Fk fixed bucket seats on sliders fitted11 months mot tax til end of monthCupra brakes all round (Drilled + Grooved discs and Ebc Greenstuff pads on front)Professionally Tinted windows (Dark Rears, light front)OBD 1 AAA Engine 1992 (early distributor type) advantage being these engine's can be dated pre gas analyasis for mot purposes therefor not needing a catalyst, emmisions are visual so totally legit!!!Custom exhaust system De-cat 2 1/4" straight through with a stainless remus back box (the sound is awesome + the flames when hot)Its running a vr6 radiator with the advantage of twin electric fansCable clutch conversion with a re-inforced pedal boxOil + filter changed every 5000 milesIbiza cupra 2.0 16v drive shafts and anti roll bar.All new ignition system from plugs to dissy, coil, leads etc etcInduction kitNew water pumpWell here are the pictures of the car It does need some work as it's no rear seats, which i need(I have a little one), bad idle and mainly tidying up (interior plastics etc). I'm hoping to do the work over the winter and have her ready for the Spring when shows/meets start up again. Link to post Share on other sites
CALICO 130 Posted September 22, 2012 Report Share Posted September 22, 2012 i think the bit about the engine not needing a cat is wrong the car was sold with a cat and therefore should have one for its mot, i may be wrong but might be worth checking out before the next one is due. Looks like a tidy install though and a clean car. Welcome to the club. Link to post Share on other sites
cj_wig 0 Posted September 22, 2012 Author Report Share Posted September 22, 2012 That's just from the ad the seller posted up. I'm going to get a cat before the MOT.It does need some work, but it's get there Link to post Share on other sites
Lukey. 381 Posted September 22, 2012 Report Share Posted September 22, 2012 think emissions regs are on the engine and the VED is counted on the chassis, but with it being a pre 2001 it would be in the same tax classification anyway.But the car coming out of the factory with a cat then having a pre cat engine conversion is a good point and seems to be a massive grey area that there is no definitive answer to Link to post Share on other sites
rsweeney 40 Posted September 22, 2012 Report Share Posted September 22, 2012 looks amazin i had a seat ibiza and rebuilt the entire engine on it before selling it, at the time i laughed about making a vr6 engine fit!did you have trouble with the wiring? Link to post Share on other sites
cj_wig 0 Posted September 23, 2012 Author Report Share Posted September 23, 2012 I bought it already done. My mate said he's had to tidy up the wiring from the last owner as it was a mess. Link to post Share on other sites
daveyboy 897 Posted November 15, 2013 Report Share Posted November 15, 2013 My mate has just bought this on Wednesday. It hasn't really changed much. It's got Ibiza cupra wheels on and that seems to be it. He loves it Link to post Share on other sites
Ickyketseddie 89 Posted November 15, 2013 Report Share Posted November 15, 2013 Cool get him signed up! always liked these! Sent from my iPad using Tapatalk Link to post Share on other sites
daveyboy 897 Posted November 15, 2013 Report Share Posted November 15, 2013 Just have mate Sent from my LT26i using Tapatalk Link to post Share on other sites
Dannost3 0 Posted November 18, 2013 Report Share Posted November 18, 2013 Ok fellas I've bought the ibiza in question not gonna do out to it it needs rear interior like but I'm just having a bit fun it it it's just lunacy absolute bonkers Link to post Share on other sites
