Woodyman84 3 Posted September 27, 2012 Report Share Posted September 27, 2012 Just trying to fix the leaks on the pipe that runs from the PCV to the Intake Elbowi have at workHot glue GunSilicon Sealant (melting point 204C)Araldite Epoxy ResinHot glue gun obv quickest but low melting point is bit worryingSilicon i think would work fine but long drying time so id be worried about fumes getting in the engineAraldite, quick drying time very rigid not sure about melting points etc.....oh and i kinda need to fix it before 5.30 lol Link to post Share on other sites
VR6Pete 1,455 Posted September 27, 2012 Report Share Posted September 27, 2012 This might be of use - http://www.vr6oc.com/e107_plugins/forum/forum_viewtopic.php?232789They are not that much new to be honest Link to post Share on other sites
Woodyman84 3 Posted September 27, 2012 Author Report Share Posted September 27, 2012 thanks for the info just looked up araldite and that has a flashpoint of 200c like the silicon,might just araldite the hell out of it for now until i can get a new one Link to post Share on other sites
russj249 2 Posted September 27, 2012 Report Share Posted September 27, 2012 I just used a jubilee clip on the intake bend so it wasn't just a push fit, it pushes in and clamps in. I couldn't pull it back out when it was tightened up. Link to post Share on other sites
russj249 2 Posted September 27, 2012 Report Share Posted September 27, 2012 That's assuming you mean where the blanked off grey plastic sensor pushes into the elbow. Link to post Share on other sites
Woodyman84 3 Posted September 27, 2012 Author Report Share Posted September 27, 2012 yeh i may add some jubilee clips as wellit does actually look like its cracked on the placstic moulding tho, so literally on the elbow itselfalso cracked on the PCV valve but then that was to be expected lol Link to post Share on other sites
russj249 2 Posted September 27, 2012 Report Share Posted September 27, 2012 Ah ok.. mine was leakih somehow between the sensor thing and the elbow itself. I think I know where you mean though.. on the elbow bit itself undearneath where the little spout is attached.I did a fix on mine which worked, but you'd have tobe super careful doing it.I used a heated up skewer to melt the plastic together where it had split. If you've ever welded before or brazed it was kind of similar, just melting both the spout bit and the elbow and getting them to fuse together. A little tricky but that's how I did mine. Link to post Share on other sites
Woodyman84 3 Posted September 27, 2012 Author Report Share Posted September 27, 2012 you know what i never thought of that, and i do surface mount soldering at work so im a dab hand at that sort of thing.its plastered in araldite now lol Link to post Share on other sites
russj249 2 Posted September 27, 2012 Report Share Posted September 27, 2012 Haha never mind, at least you can have a go if the araldite doesn't work. Could use an old soldering iron to do it with, that way you won't have to keep heating up a skewer or screwdriver. Link to post Share on other sites
Daverse 175 Posted September 27, 2012 Report Share Posted September 27, 2012 Youve just reminded me i need some more soldering iron tips. A bit off topic i know but important none the less Link to post Share on other sites
Woodyman84 3 Posted September 27, 2012 Author Report Share Posted September 27, 2012 ive got a rework kit with every possible tip you could ever wantim sure i must have lead poisoning by now tho!! Link to post Share on other sites
Daverse 175 Posted September 27, 2012 Report Share Posted September 27, 2012 Haha nothing like huffing them solder fumes Link to post Share on other sites
Daverse 175 Posted September 27, 2012 Report Share Posted September 27, 2012 Double post - please delete Link to post Share on other sites
