Wilsonp83 1 Posted October 16, 2012 Report Share Posted October 16, 2012 HI there everyone, I find myself in need of some expertise again.97 R Mk3 VR6 HighlineRear wiper motor had failed but wash jet still operated only not much water was ejected from nozzle. Upon removal (and reading a fair bit on the internet) it was obvious that the nozzle was broken and leaked inside the motor.First port of call was to GSF for a replacement and at the time thought ~£70 was a bit dear and found plenty on eBay for a lot less. Long story short and 3 motors later (all the nozzles were snapped and "sold as seen") , I bought one from GSF.Problem now is that I get a strong jet of fluid from the nozzle but the motor fails to operate. The motor is (to me) obviously getting power, I checked the fuse though but it's fine.Having checked the Haynes manual for fuses and relays, it seems that there are no independent fuses or relays for the rear wipe. Everything else seems to be working, so really I am at a loss and this is my last resort before either calling an auto electrician or taking it to SJB Autotech or similar.Any help would be appreciated as always.Cheers,Jay Link to post Share on other sites
Lukey. 381 Posted October 16, 2012 Report Share Posted October 16, 2012 First you need to make sure it's getting power with a multi meter, using the chassis as a ground, if no 12v then you have a power problem, if there is 12v while chassis grounded then you likely have a bad earth Link to post Share on other sites
Wilsonp83 1 Posted October 17, 2012 Author Report Share Posted October 17, 2012 Thanks for that. i will try and have a look during the week but i suspect it'll be the weekend. i will keep you posted with what i find. cheersjay Link to post Share on other sites
Wilsonp83 1 Posted October 21, 2012 Author Report Share Posted October 21, 2012 Ok guys. bad news is that checking with a multi meter shows it is getting at least 12v. so bad earth you say? How do i go about tackling this one then? Cheers all Link to post Share on other sites
CALICO 130 Posted October 21, 2012 Report Share Posted October 21, 2012 Run an earth from the battery and connect it to one of the bolts on the motor and see if there's any difference Link to post Share on other sites
Wilsonp83 1 Posted January 7, 2013 Author Report Share Posted January 7, 2013 Ok got a few more pressing problems now but I will re-attack this when I get chance. Thanks calico Link to post Share on other sites
