vr6turbo 27 Posted October 20, 2012 Report Share Posted October 20, 2012 Hi Guys have a problem with my vr6 pulling to the leftthe front and rear suspension has been fully rebuilt new rear bushestop mounts and bearings all roundkoni adjustable shocks and hr springsthe car sits well at the same heightwish bones doneball jointstrack rod endsanti roll bar link armseverything good quality and brand newwhat i know is the calipers are not stickingthe car is levelthe tracking has been done twicecamber set at 1 degree neg checked twicethe symptoms arewhen i let go of the steering wheel on a flat road the car veers to the left not violently thoughthe steering to the left feels lighter thank the steering to the rightquestions does the steering rack have to be centered as far as the tie rods are concernedcould the problem be the alignment of the rear beam as this was totally refurbed with new poly bushesboth brackets were taken off as wellany ideas previous experience with this problem is greatly appreciated :-p Link to post Share on other sites
Lukey. 381 Posted October 20, 2012 Report Share Posted October 20, 2012 Could be your tyres if they have worn in a bit funny Link to post Share on other sites
russj249 2 Posted October 21, 2012 Report Share Posted October 21, 2012 I have this problem too.. had my tracking done loads of times at different places, New everything has been fitted inc. Coilivers and it still pulls slightly to the left, meaning I have to hold down on the right side of the wheel constantly (not hard, but just to support it)Also I had it on old mix of 4 different tyres on standard vr6 wheels, then 4 Goodyear eagle f1's on bbs, and now 4 brand new Pirelli P Zero's so can rule out tyres for me! Link to post Share on other sites
vr6turbo 27 Posted October 21, 2012 Author Report Share Posted October 21, 2012 all four tyres are fine nearly new and have been checked by the tyre fitting placethanks for the input Link to post Share on other sites
Timah89 1 Posted October 22, 2012 Report Share Posted October 22, 2012 alot of roads are cambered to allow for water to flow off the road to the drains. might not be the cause but could be making it feel worse than it is Link to post Share on other sites
Lukey. 381 Posted October 22, 2012 Report Share Posted October 22, 2012 all four tyres are fine nearly new and have been checked by the tyre fitting placethanks for the inputNo worries, just I had this very problem on a car years ago, it had stock suspension with few month old tyres then I had lowered suspension fitted and aligned up perfectly and it pulled, I put brand new tyres on and the problem disappeared. Link to post Share on other sites
vr6turbo 27 Posted October 24, 2012 Author Report Share Posted October 24, 2012 Hi all the garage swapped the rear tyres for the front to see if that made any difference guess whatit didn'tThe only thing that sticks in my mind is the passenger side wishbone was a bit of a T@@t to fit almost as if the bushes were not lined up properly so I need to look at that. Also the gap between the rear of the front tyre and the arch seems different to the drivers side further investigation neededI have rebuilt a few vr6 suspensions and this is the first time I have had problems. Link to post Share on other sites
rodney 17 Posted October 24, 2012 Report Share Posted October 24, 2012 Does it do it more on braking?I ask as there are several main items, some of which you have already addressed. But for completeness here ya go..Tracking... New suspension can take up to 500miles to settle especially if you do other areas at the same time (did you tripple measure each corner for spring length and damper settings)Tyres - wear levels and pressure differences... a rear can affect the front so dont just check the front. (of course all 4 must be the same make & tread pattern etc)Brakes... again a rear can affect the front so check them as well as the front.Under breaking... This would indicate either a grabbing brake or you are not aligned correctly or a pressure issue or of course something is not quite tight... Finally dont forget if the springs and dampers are not all set identically then you can of course see and feel the effects in this way as well.. After all a soggy shock will cause the same/similar effect...As mentioned roads do have a natural run off generally so see if it is the same on a the other side of the road... When safe of course... I hope it all helpsgood luck Link to post Share on other sites
