Gordo91 0 Posted October 29, 2012 Report Share Posted October 29, 2012 Had a problem twice with the dipstick popping out causing an awful mess and replaced the seal as it was almost flat and didnt seal very good , now its sealing i have a breather from the rockercover at the o/s which is going to nothing as the intake system is differnt due to supercharger and keeps leaking oil , any ideas around this or a system to filter it back to engine? Link to post Share on other sites
Daverse 175 Posted October 29, 2012 Report Share Posted October 29, 2012 I believe a catch can will fix the leaking out of the crankcase breather Link to post Share on other sites
Gordo91 0 Posted October 29, 2012 Author Report Share Posted October 29, 2012 I thought this but theres quite a bit of oil whcich would mean draining it back in alot :/ Link to post Share on other sites
matty.vrt 120 Posted October 30, 2012 Report Share Posted October 30, 2012 I'm guessing your piston rings are goosed causing cylinder pressure to leak onto the crank case alternatively worn valve seals could have the same effect. Link to post Share on other sites
Pieman 0 Posted October 30, 2012 Report Share Posted October 30, 2012 As above. I think you need to do a compression test. Link to post Share on other sites
rodney 17 Posted October 30, 2012 Report Share Posted October 30, 2012 just some background.... Are you connected up thusly????http://www.vr6oc.com/e107_plugins/forum/forum_viewtopic.php?1298942nd post has the pretty diagram Link to post Share on other sites
rodney 17 Posted November 1, 2012 Report Share Posted November 1, 2012 alos what sized pipe you runnning from the crank case? If to small then will restrict air flow and thus build pressure elsewhere??? Link to post Share on other sites
