Light are playing up
Hi everyone,
My interior light has started to come on when the door is closed, the smaller map light next to it flickers & now the rear indicators & rear fog light come on when I press the brake pedal instead of the brake lights !
Has anyone else had this, is there a module that controls the lights ?
Thanks for any help.
Baz
The simplest way to determine is to get a long piece of wire, clip it to the negative battery terminal and at the lights connect the other end of this wire to the earth wire and see if the problem goes away, if it does then you know where to begin from making a better earth connection.
A safer way is to connect the terminal end of the wire to an unpainted piece of chassis metal, but this relies on the main earth to the battery being solid.
